Old 04-22-2009, 06:00 PM   #871
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yeah I've heard that this car is durable and fun to run. I'm always down for "different" especially when it looks cool!
Let me know if anyone has one for sale.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-22-2009, 07:23 PM   #872
linger's Avatar
Originally Posted by Randy_Pike View Post
Anyone able to find this IFS R Car right now? Everywhere shows on B/O.
I might try this car in the RCGT class.
Randy - two of the fastest guys running RCGT in the Norcal area at running TA05-IFS R's. They look cool as hell and they run pretty damn fast too. The last couple times out - me and Arluck are 1 lap faster than the "regular" 17.5 class and we do it with more "style."
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 04-22-2009, 08:33 PM   #873
Trader Rating: 22 (100%+)
Randy,
Try Ultimate Hobbies. They currently show in stock.
littleZEN is offline   Reply With Quote
Old 04-25-2009, 01:24 PM   #874
Trader Rating: 35 (100%+)
Default performance difference?
A fellow racer suggested that my lap times (17.5 brushless) could improve if I used a body like the Protoform Mazda6 rather than the Tamiya NSX (IFS) body.
What bodies do you guys use for non-Tamiya club events?
Geppetto is offline   Reply With Quote
Old 04-25-2009, 01:47 PM   #875
Foxxrocket's Avatar
I like the mazdaspd6. It's the best of both worlds.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 04-26-2009, 06:47 AM   #876
Solara's Avatar
Trader Rating: 16 (100%+)
Anyone mind to share a good indoor carpet setup for 17.5? I am converting my 05R to IFS-R and would like to see the different (in setup) especially now the front shocks are going FLAT...thanks.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 04-26-2009, 02:58 PM   #877
Default Gear suggestions
Almost have my new IFS running. I've decided to not bother with the Stock 540 motor, and to put in my X-Star 27T motor. Because I haven't done anything R/C related in about 6 years, I am unsure how much faster this motor will be, and what pinion I should use.
Stock gearing is 70 tooth spur & 22 tooth Pinion. Will I be okay still with that or should I go 24 tooth?
I also have a 14T (Speed Gems 2). Any help or Gear ratio to motor chart available?
RepaF1 is offline   Reply With Quote
Old 04-27-2009, 12:26 PM   #878
Solara's Avatar
Are you using the IFS just for bashing..? If so...your 14T would be the fastest thing, then 27T and then the silver can...
But if you are racing....then you have to find out what class you are going to race in...27T is stock, raced again BRUSHLESS 17.5. Silver can = GT3 class if your club has one...14T is definitely MOD...
Since you are out for awhile, BRUSHED motor is going away...most ppl are running BRUSHLESS motor...stock like 17.5 and super stock like 13.5 are the biggest class...may be some 21.5 for USVTA class. So...ask around and find out what are the classes that you are racing in.
Last...for your 27T, you want your final gear around 7.5. Your IFS internal is 2.055 (if that is the same as IFS-R) and lets say you want to use your 70T spur, then you must have pinion like 17, 18 and 19...and 19T is probably the tallest that you want to go or your motor will get too hot....18T is a safe gear to try, if too slow, gear up 1 to 19T...
Alot of ppl using online gear chart like this one, fill in the blanks and print out the chart and use it at the track...
www.gearchart.com
Old 04-27-2009, 02:39 PM   #879
www.gearchart.com
I believe the IFS is the same as the TA05 (not the same as the IFS-R) so my ratio would be 2.5 if I remember. Using that gearchart... what would my motor RPM be for the 27T ?
Old 04-27-2009, 04:50 PM   #880
the std ta05 and ifs has 2.25
Hatebreed is offline   Reply With Quote
Old 05-08-2009, 09:16 AM   #881
stitchy's Avatar
Does anyone have a problem with their 1510 outdrive bearings seizing? I've had two go bad and one of them was ceramic!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 05-09-2009, 03:43 AM   #882
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
Anyone have any tips on how to remove the c-clips from the layshaft??? I need to replace the pulleys, but am having a tough time getting the c-clips off so I can change out the pulleys.
For once, I'm actually wishing there was an E-clip instead. hehe.
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 05-09-2009, 04:29 AM   #883
cheehtae's Avatar
Trader Rating: 15 (100%+)
no problem with mine, must be a bad batch. Anyways try avidrc they sell good bb's.
cheehtae is offline   Reply With Quote
Old 05-09-2009, 04:37 AM   #884
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
ifs cars are 2.055, standard 05s are 2.25
R
UltegraSTI is offline   Reply With Quote
Old 05-10-2009, 01:13 AM   #885
stonedgti's Avatar
Just got the IFS-R. Is there a One-way and Spool for it? Also, what diff rings does it use. It's all different then my regular TA05.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
