Tamiya TA05 IFS
#856
With the IFS, you can use bodies that have more downforce. Normally the shocks would get in the way. But there are not many companies outside of tamiya that make bodies that take advantage of the car's layout. The best part about the kit is, that it comes with all the parts to make a normal TA05.
#857
You need to buy the shock tower set to get the front shock tower if you want to convert it to the regular R. but everything else is included
#858
Hi
Im looking at buying a Tamiya TA05 IFS or the TA05 IFS R but its the TA05 IFS R a TRF kit if so it will be a problem to get parts for as for some reason TRF parts are very hard to import, also does the IFS provoid any real advantage with the shock position compared to the oringinal TA05? and is the IFS better than the oringial TA05 chassis. All infor will be greatly appreciated.
#859
I live in Australia. TRF parts are not easy to get hold of as many hobby shops in Australia deal with Tamiya but dont stock TRF parts or kits, still is the TA05 IFS R a TRF kit? for the reason stated above, I just like to have good parts support in case if I break anything during a local club meet.
#860
I'd say the TA05 IFS-R!!!!!!! I love mine, I cant tell a difference between my 416 and TA05. Both handle amazing, perfect for parking lot asphalt racing. I did the kit set up with no sway bars, set ride height to 6mm and the things dialed
#861
http://rcmarket.com.hk/index.php?cPath=51_98_120_133
#863
#864
Im jumping head first into this car any spares and notable things that have to be changed from the non r version that i should get myself. Im only going to do local club things on an asphalt track in not getting to into electric touring racing yet.
#865
I've got an IFS-R"-ish" car that was converted from a TA-05R with the old pulleys and front spool.
Question: Could I simply replace the (16 tooth) center pulley with an 18 tooth one and use with my existing 36 tooth pulleys to create a drive ratio of 2.0? If so, what belts would I use?
If not, and I have to get the 37 tooth outer pulleys too, would I just get the normal pulley to use with my spool? Thanks!
#866
TA05 IFS-R Setup Suggestions?
I need help finding a good starting point for our local track. Now that the TCS Race is over, I'm looking to race my IFS-R in the 17.5 stock class at our track. Our track is an indoor asphalt, high traction smooth and flat.
The setup I used for the TCS race (GT3) felt spot on for my driving style. I installed the 17.5 setup in the car and something happened. What felt like a perfectly balanced, easy to control car during TCS became just the opposite with the brushless setup.
My current setup is:
The other weekend racers run Xrays for the most part. The tire of choice is the Jaco Prism Rubber blue w/ no smell traction compound.
There is only one other guy racing a Tamiya chassis in this class at our track. He has a TB03, and he's having difficulty finding a setup he is happy with.
I'm open for any and all comments and suggestions.
- No sway bars
- short white (hard) springs (f/r)
- 1.5 degree camber (f/r)
- 50wt oil w/3 hole pistons
- 6 mm droop (f/r)
- I ran B-type tires for the TCS
#867
I am using blue in the rear,yellow in the front, 85wt oil in the rear,70wt oil in the front and 2 hole valve plates front and rear.I find very little caster suits me, toe in front and rear at 1 deg.Setup is a personal feeling though.Outdoor is much different than carpet indoor ia am finding.
#868
Anyone able to find this IFS R Car right now? Everywhere shows on B/O.
I might try this car in the RCGT class.
#869
- No sway bars
- 6 mm droop (f/r)
