Old 03-12-2009, 01:37 PM   #826
TwoTone's Avatar
Originally Posted by padailey View Post
Thanks guys... one more question for now.... does the IFS-R suffer from the same static buildup problem as the TA05 R. On the tamiya site it mentions this problem for the R but not the IFS-R. I know where to run the little wire but wondering if I need to?
I would assume yes since the only real change is the suspension mounting
TwoTone is offline   Reply With Quote
Old 03-12-2009, 02:52 PM   #827
padailey's Avatar
Kinda what I was thinking also but just surprised it was mentioned on one car but not the other.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 03-12-2009, 03:12 PM   #828
syndr0me's Avatar
Trader Rating: 32 (100%+)
With the stock chassis, static is definitely still an issue. The jumper wire trick seems to fix it. The carbon reinforced tub does as well.
On rubber tire/carpet, the sway bars made the car lean quite a bit less, and it felt a lot more predictable. I'm not running anything resembling the original kit or its setup now, though.
syndr0me is offline   Reply With Quote
Old 03-12-2009, 03:13 PM   #829
syndr0me's Avatar
Remember those special edition blue plastic parts? I realize they're more brittle, but is it safe to at least run the body posts, or will those snap as well? I like how they look. :-)
Old 03-12-2009, 03:28 PM   #830
syndr0me's Avatar
Well, we're having our "big" 3-day race this weekend, and figure on getting 75-100 entries, most of them local. On-road is alive and well in Denver. Anyway, I've decided to shelve my 416 and take the TA05 into battle in 13.5 and 17.5 rubber. We'll see how it goes! Since the car started its life as a TA05 IFS-R, I'll post it here. It's been through a lot since its early days. :-)
Old 03-12-2009, 05:31 PM   #831
Looks very nice! You don't seem to have the battery clamp screws, how do you secure your battery? Do the alloy bulkheads make a lot of difference on outdoor asphalt? They sure are costly though...
stocker is offline   Reply With Quote
Old 03-12-2009, 05:35 PM   #832
Core Creations's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to Core Creations
I'd bet he tapes. It had better be BLUE tape!!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 03-12-2009, 05:41 PM   #833
syndr0me's Avatar
Yeah, I tape, but the only thing I have in that width currently is black tape! :-O
To be honest, I don't think the aluminum bulkheads make much of a difference, aside from being a lot more convenient. I race on high-grip carpet, so a stiffer car seems to work a lot better. If I were racing outside, I'd probably roll with a soft, stock car.
My version of the car isn't a budget racer by any stretch. It's got a bunch of little parts from a 416 on it, as well as many of the hop ups. It pretty much eliminates any opportunity to joke around with people about getting beat by a tub car, 'cause I probably spent more than them. :-D I built this car up, because somewhere deep inside, this is still a hobby, and doing that was a lot of fun. The fact that it's performing so well for me now has been greatly rewarding.
Old 03-12-2009, 05:49 PM   #834
Thanks, but what are the advantages of taping over the clamp?
Old 03-12-2009, 06:59 PM   #835
syndr0me's Avatar
The clamp gets uncomfortably close to the wires on my ThunderPower batteries. I regret buying them for a number of reasons, including their insistence on taking up both corners with wire exits. At least SMC got that figured out.
Old 03-13-2009, 08:07 AM   #836
Regional Moderator
Darkseid's Avatar
Gotta say that this whole static thing has always been a mystery to me.
Yeah, when running my IFS-R on carpet my car has static when it comes off the track, but so did my original TA05-R (with and without the carbon chassis), my Tamiya mini, Tamiya F103, my Mi3 when I ran that, that guy over there with his RDX, that guy over there with Losi Type-R, etc...etc...
Never quite got why it was such a big deal about it with the TA05. Especially to require grounding wires and all that.
TLR 22...Tamiya F104...
Old 03-13-2009, 08:33 AM   #837
TwoTone's Avatar
It's been ages since I worked on aircraft, but here a quick very simplified explanation. When static builds up, it looks for a place to ground. Depending on a lot of factors, it will 'pick' the easiest place to discharge.
All the chassis you mention have different designs. Base on the release Tamiya made, I just think they hit the lotto with that design so that the static discharges in a way that glitches the eletronics
Old 03-13-2009, 11:54 AM   #838
Foxxrocket's Avatar
How much tension should be on the belts? With this being my first belt car, it's hard too tell if it's too loose or too tight. With the motor removed from my TC4, the wheels run super free. I suspect it's different with belt cars?
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 03-15-2009, 05:39 PM   #839
arj
Hi guys
I want to try a few different suspension block settings. Tamiya make blocks with a notch for the belt to pass through. Do i need these on the Front/Rear and/or the Rear/Front, or can I just use the normal ones without the notch for these positions.
Adrian
arj is offline   Reply With Quote
Old 03-15-2009, 05:47 PM   #840
GCT69's Avatar
Originally Posted by arj View Post
Hi guys
Adrian
you can flip the blocks for the belts to pass throught it.
GCT69 is offline   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
