Old 02-19-2009, 03:56 AM   #781
GCT69's Avatar
Originally Posted by arj View Post
Hi guys
I wanted to put carbon reinforced front knuckles onto my standard TA05 IFS. I can't seem to find the part # for this. Anyone know if I can use the TA05 ones or another one from a different model?
Arj
if your using IFS r then it's using the same knuckles as the 416, try ampdraw.com
GCT69 is offline   Reply With Quote
Old 02-19-2009, 11:30 AM   #782
arj
Thanks GCT69
No, I don't have the IFS-R, just the standard IFS. I think the IFS has the shorter suspension which is why they may be different knuckles.
Anyone out there get a carbon reinforced front steering knuckle into a IFS?
arj is offline   Reply With Quote
Old 02-19-2009, 05:10 PM   #783
GCT69's Avatar
Thanks GCT69
well if it has a short susp. then I guess you could use the carbon reinforced. Do you have a part #?
Old 02-19-2009, 05:42 PM   #784
inconceivable's Avatar
Originally Posted by STLNLST View Post
Go to the 415 or 416 threads. There's a guy on there named TRYHARD that posted some links to his website that explains it all. I believe the the links are still on the current page on the 415 thread and may be one pager or so back on the 416 thread. This info would even teach Marc R. a thing or two
Found it at http://www.thard.co.uk/viewtopic.php?f=24&t=30
This is great information, thanks !
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 02-20-2009, 10:08 AM   #785
STLNLST's Avatar
Trader Rating: 19 (100%+)
My brian hurts from all the info....
STLNLST is offline   Reply With Quote
Old 02-20-2009, 12:10 PM   #786
arj
OK here is what I can gather w.r.t the front steering knuckles:
Model............Glass Filled.....Carbon Filled
TA05.............50867...........53579
TA05IFS.........51296...........????
TA05IFS-R......n/a...............51332 (not certain if this is carbon or glass)
So I have the TA05IFS (with standard suspension, not the short one) and am wondering if Tamiya makes a carbon filled part for the IFS or whether another one might fit.
Old 02-20-2009, 06:09 PM   #787
GCT69's Avatar
best thing to do is e-mail tamiya usa itself, they are pretty fast in replyin.
Anybody fitted their IFS with a gt10 body? I'm thinking of putting one in but don't know where I can get one. ( Various selection?
Old 02-21-2009, 01:40 AM   #788
what oil should i fill the trf dampers with? what i can see in most cases people uses 40wt/3holes in the front and 30wt/3holes in the rear or am i wrong here?
also the diffs are quite open with the 37t pulleys, are there any ways to protect them from collecting dust, as they are now they need to be rebuilt quite often i can imagine
Hatebreed is offline   Reply With Quote
Old 02-21-2009, 04:54 AM   #789
cheehtae's Avatar
Trader Rating: 15 (100%+)
Depends on what surface you racing, I used AE 50wt in front with 3 holes and tamiya yellow on my rear with three holes. As far as diff covers , ck out rcmart or some HK stores, I think they sell em. (search under TRF 416)
cheehtae is offline   Reply With Quote
Old 02-25-2009, 05:47 PM   #790
Trader Rating: 35 (100%+)
Default I need some help, thoroughly frustrated!!!
I'm trying to adjust downstop/droop on my IFS-R, and I'm having serious trouble getting this to work. Either my chassis is way off, or I have done something wrong and can't figure it out.
See attached photos.
No matter what I try, the battery side rear arm is about 3mm higher than
the motor side rear. The droop screws are backed out completely. I have loosened all the screws on the bottom of the chassis thinking maybe tweak. I have removed the arms and reinstalled them. I can't figure this one out.
We have a TCS race (my first) in 3 weeks, and I haven't had any quality track time with this chassis.
HELP!!!
Tamiya TA05 IFS-chassis1.jpg   Tamiya TA05 IFS-chassis-motor-side.jpg   Tamiya TA05 IFS-chassis_battery-side.jpg
Geppetto is offline   Reply With Quote
Old 02-25-2009, 05:50 PM   #791
Hebiki's Avatar
Trader Rating: 26 (100%+)
HELP!!!
make sure your chassis is flat
check to see if the hinge pin for the screwy arm is straight
loosen the suspension blocks and tighten them down in a cross pattern
also check to see if your arms move freely up and down
thats all i can think of .....
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-25-2009, 06:06 PM   #792
TwoTone's Avatar
HELP!!!
Looks like to me you have the wrong type of suspension mount in the front of the rear. Looks like a rear mount that's been flipped over.
Should look like this: (these are the front ends rear mount and the rear ends front mount)
Where as it looks like you have a normal one flipped over since I don't see the lettering on top. (These are the front ends front mount and the rear ends rear mount.
TwoTone is offline   Reply With Quote
Old 02-25-2009, 07:54 PM   #793
DRAG_ON's Avatar
HELP!!!
i got this similar problem before, i find out my hinge pin is bent .......... my suggestion check your hinge pin mate ......... it might solve your problems
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 02-26-2009, 06:40 AM   #794
Yeah. The chassis seemed to rock slightly, but it's tough to tell because the edges of the chassis are curved. I think that it's pretty flat though. Your other suggestions I already tried.
Old 02-26-2009, 06:41 AM   #795
Yeah, I looked at that also. Unfortunately, I haven't had enough track time to bend or break anything.
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
