Old 01-30-2009, 12:56 PM   #751
TwoTone's Avatar
Originally Posted by Geppetto View Post
Thanks for posting the photos.
Looks like I could ditch the fan??? At least that's what I was hoping. Also looks like you have shortened the sensor wire???
Larry, if I'm not mistaken, I think every Brushless except Novak has asensor wire with plugs at both ends. Which means you can buy short wires and don't have to shorten them yourself like a novak.
TwoTone is offline   Reply With Quote
Old 01-30-2009, 03:16 PM   #752
Just ordered a standard tA05, have some q`s
how will the diffs hold up in mod, should i change outdrives before i throw in a 5.5 motor?
Hatebreed is offline   Reply With Quote
Old 01-30-2009, 03:23 PM   #753
cheehtae's Avatar
Trader Rating: 15 (100%+)
definitely get the alum. if your running mod.
cheehtae is offline   Reply With Quote
Old 01-30-2009, 03:51 PM   #754
Trader Rating: 35 (100%+)
I noticed that. It would be nice if I could source the plug (molex, I think), and the metal clips that fit into the plug. The plug looks similar to the plug used on my LiPo charger. Hmm...
Geppetto is offline   Reply With Quote
Old 01-30-2009, 05:56 PM   #755
TwoTone's Avatar
If you do it the way I described, it won't look bad when done, just don't forget the large black shrink for once you've done the individual wires.
Old 01-31-2009, 07:56 AM   #756
The sensor wire is a really short one that came with a SpeedPassion 13.5 I have.
Did you install the Speed Passion 13.5 in your TAo5? If so, how did you get the sensor connector to clear the side brace on the chassis?
retepw45 is offline   Reply With Quote
Old 01-31-2009, 09:04 AM   #757
reenmachine's Avatar
Trader Rating: 26 (100%+)
I trimmed some material from the side brace. I'll see if I can post a pic later.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 02-02-2009, 10:23 AM   #758
sorry about the wait. here is the base setting from the Tamiya book.
couple things to know:
1. forgot to put push rod length. mine is 13mm
2. All the ball studs use the newer hex ball ones.
https://www.speedtechrc.com/store/eb...id=250&id=6257
These are 1mm lower than the standard balls, so be sure to subtract 1mm if you use the older ones.
3. this set up makes the car really narrow. car handles quite well with a spool. Never tried double one-way, which still seems to be the choice for asphalt in Japan. This setting is for use with double oneway
http://img124.imageshack.us/img124/1219/ta05ifsrzw2.jpg
redbones is offline   Reply With Quote
Old 02-09-2009, 05:21 AM   #759
Default Body mount posts
Are the body mount post found on the TAM51242 parts tree, the only post that fit the TA05 IFS, without having to re-drill body holes?
I'm having the hardest time finding a shop (online or locally) that has most of the parts that I want/need. Seems I have to purchase small parts from multiple places typically from overseas.
On a positive note, I ran a few laps on my IFS-R (with "flag pole" body post, unglued tires and an unpainted body) between heats of the Spec TT-01 Class I race in and boy is 17.5 fast. Years ago I raced 27t brushed and it never felt this fast. Maybe it's just that I have been racing these Red Dot motors in the TT-01 for the past several months, and I've forgotten what speed is like. I've got to get used to this speed in a little over a month. The TCS event will be here before I know it.
The car felt really good despite the fact that I haven't fine tuned it. No matter what happens in the TCS event, I think that the TA05 IFS is a keeper!
Old 02-10-2009, 07:28 PM   #760
Trader Rating: 112 (100%+)
Does anyone have a good starting setup for Carpet/17.5?
Dave
dragracer72nova is offline   Reply With Quote
Old 02-10-2009, 07:45 PM   #761
xrayroooahhhh's Avatar
I like the fact the I.F.S. is sooo different in design.....can someone tell me what a guy could expect from this chassis vs. a touring car with more traditional front suspension relating to handling....maintenance....set-up?? This car would be running 17.5 stock.
Thanks....thinking of getting one.....just would like to hear some opinions!!!
R
-ROOH RACING-
www.donerite.net
xrayroooahhhh is offline   Reply With Quote
Old 02-10-2009, 08:47 PM   #762
R
My experience with the many Tamiya kits I've built is to try the kit default setup first. They seem to put a lot of thought and testing into that. I just raced my IFS-R for the first time Sunday in two classes: 17.5 Sedan and RCGT (RCGT is 17.5 on HPI X-pattern tires with a realistic body). High-bite outdoor asphalt. I never touched the setup from the default -- it was absolutely dialed and I was smoother, faster, and more competitive than ever before.
Build it very carefully to the kit box setup and go from there.
Pete Waydo
Old 02-11-2009, 04:28 AM   #763
cheehtae's Avatar
[QUOTE=dragracer72nova;5415730]Does anyone have a good starting setup for Carpet/17.5?
Dave[/QUOTE
foam or rubber?
Old 02-11-2009, 04:38 AM   #764
tc3team's Avatar
+1. The only exception to that is if you plan on using foam tyres, then I probably would look at getting some stiffer springs and maybe some sway bars to help the handling
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-11-2009, 03:16 PM   #765
Originally Posted by cheehtae View Post
foam or rubber?
Rubber
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
