Old 01-28-2009, 11:57 AM   #721
Trader Rating: 35 (100%+)
Originally Posted by reenmachine View Post
Yeah, those are the "red" springs. Tamiya makes a set identical to the one redbones linked to but with all-white springs except for a dot at one end identifying the color. This is so other guys at the track can't tell what setup you're running. The standard sway bar kit is color coded as well, but the IFS-R comes with the "stealth" all-black bars for the same counter-espionage reason.
Also like redbones said, it is common to use a slightly harder spring up front than in the rear. If you find that you have oversteer that is the first thing I'd try. Go to yellows in the front and keep the reds in the rear.
I get many of my Tamiya parts from speedtech (www.speedtechrc.com). They're in the Los Angeles area and are a great shop and strong supporters of the hobby. Stuff they don't carry I order from Hong Kong or Japan.
Here's the spring set you should get (they're out of stock right now but here's the info):
springs at speedtech
Stealth Springs. I like that. I'm very familiar with Speedtech. Back in 2005 on a visit to San Diego (my wife is from SD), I stopped by Speedtech on our way to San Bernadino.
I also bought my IFS-R from them.
Geppetto is offline   Reply With Quote
Old 01-28-2009, 12:00 PM   #722
stitchy's Avatar
Originally Posted by redbones View Post
yes, you need to swap them to the rear of the tower.
thanks!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 01-28-2009, 12:01 PM   #723
Default Gearing Help
I got my motor/ESC. Novak GTB w/17.5. Where do I begin with gearing? This would be for the GT2 class of TCS. I'm attaching a photo of the track (just before it opened).
Currently, the only spur and pinion I have is the one that came with the kit. Other than that all I have is TT-01 (19t\61t).
Thanks guys!
Old 01-28-2009, 12:26 PM   #724
reenmachine's Avatar
Trader Rating: 26 (100%+)
Thanks guys!
We start with an FDR of about 3.6 out here, but that may be a bit tall for a tighter track. It's hard to tell from the photo, but maybe start there and adjust according to motor temps. Try not to exceed 165-170F at the end of a race distance.
You'll need a smaller spur and larger pinion than those from the kit. Actually, I don't think the kit came with a pinion...
I run an 87T spur and 49T (FDR 3.63) or 50T (FDR 3.56) pinion. Speedtech has the gears. Those are 64p gears.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 01-28-2009, 04:05 PM   #725
Those white ones that reenmachine posted are the same exact ones, just white. There is also the limited milky blue ones, which are the same as well. Kinda confusing imo.
I get my stuff from speedtech, and HK. HK stuff can get here in about a week if they ship it out fast. What sucks the most is when you have to order from multiple vendors since one store doesn't have everything you need.
for 17.5, I run about 4.5fdr. Out track is technical so need that bottom end. Go for under 4.0 if you have a long straight. Watch the temp though, I try to keep everything under 170F. pretty much what reenmachine says.
I copied a setting sheet from the TA05/TB03 guide book from Tamiya and works pretty good for me. Satoshi's recommended starting point for the IFS-R. I'll try to post it later on.
redbones is offline   Reply With Quote
Old 01-28-2009, 04:36 PM   #726
Please do. I'd be interested in seeing that.
Pete Waydo
Old 01-28-2009, 05:56 PM   #727
cheehtae's Avatar
Trader Rating: 15 (100%+)
Your car is almost 100g lighter with that conversion so you need to change everything. You lost the chassis flex from the tub, so you will have to to change the shock settings to compensate. You can also fiddle with the steering setting on your radio to make the car less reactive.
BTW, I'm running foam on rug, my front spring is purple and rear is white, 50wt front, tamiya yellow on rear SHock fluid). Will try Blue springs on the rear this weekend. Will see. TNX guys.
cheehtae is offline   Reply With Quote
Old 01-29-2009, 01:34 AM   #728
teddy_ifa's Avatar
me too, im interested to see that setting sheet for my ta05 ifs-r
TAMIYA TA05 IFS-R* TAMIYA TA05R * FUTABA 3PM * SANWA M11X * SURGE CRUSHER DOUBLE HULL BRUSHLESS SPEEDBOAT * 3RACING * YEAH RACING * HOBBY WING * HPI * ORION * TRAXXAS REVO 3.3 * LRP * XRAY T2R PRO * THUNDER TIGER 1:5 NITRO MOTORBIKE *
teddy_ifa is offline   Reply With Quote
Old 01-29-2009, 02:44 PM   #729
cheehtae's Avatar
Anybody using a 3racing chassis here noticed that they're chassis is tweaked? I think mine is. I think it has something to do with the Bulkhead since I'm using the stock ones that came with the IFS r. I noticed it when i tightened the screws ( just like tightening wheels on cars) when I lay it on the plexi it was tweaked so I had to loosen the screws and lay it again and there is still minimal tweak but not as noticeable as before. So with guys that have alloy BH do you have this problem? Just on my front BTW>
Old 01-29-2009, 05:23 PM   #730
anyone have photos of their chassis with a brushless system (motor and ESC) installed. Preferably, Novak GTB. I'm completely lost on this one. This ESC seems to have wires coming from everywhere, and then there's the huge cap!
This is my first brushless.
Old 01-29-2009, 05:40 PM   #731
TwoTone's Avatar
Not a GTB, but I still had to lay the ESC on its side to fit.
Post number 115:
Inspire us. Show me your BEST, CLEANEST electronics installation pics.
TwoTone is offline   Reply With Quote
Old 01-29-2009, 11:10 PM   #732
inconceivable's Avatar
I've been running my IFS-R for about a month now and have noticed a bit of understeer (push). It seems most noticable at the end of the straight (regardless of track I run). To get around these sweeping turns I need to back off the throttle significantly. I'm running 40wt oil in the front with blue springs and 30wt in the rear with yellow springs. Camber is set at -1 all around with about 1/2 degree of toe in. Ride height is 4mm in the front and about 4.5 in the back. All blocks are the stock ones that came with the kit. I was originally running both sway bars, then just the rear, now I've removed both. Any suggestions would be greatly appreciated. I've been running TC's for some time, but this IFS is new to me. Thanks.
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 01-30-2009, 01:51 AM   #733
try loosening up your front diff, if you're using a diff up front.
Tamiya - Awesomatix - Orca - Orion - LRP - Protoform - Sanwa - Futaba - NASA - Ride
Minami is offline   Reply With Quote
Old 01-30-2009, 04:08 AM   #734
Post number 115:
You certainly got it all in there. Is that the capacitor/diode encased in the
shrink tubing? Also, did you shorten the sensor wire, if so how? My sensor wire is to long. Does your ESC have a cooling fan.
I like your idea of mounting the ESC on the side, but I'm concerned about overheating the ESC.
That's an interesting thread. Some really clean installs. When I'm done, I don't think that my install will win any clean install rewards.
Old 01-30-2009, 05:01 AM   #735
Trader Rating: 17 (100%+)
The GTB will fit,just, if you thin down the divider in the back of tub behind the motor, have the power wires face the belt, and zip tie the cap to rear bulkhead brace.
billb60 is offline   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
