Old 01-05-2009, 06:44 AM   #601
TwoTone's Avatar
Originally Posted by reenmachine View Post
Yes, you have to cut one of the inboard ears no matter what servo you use. It also says that you may have to cut the tub adjacent to the servo saver to allow full range of motion. On mine, if I don't cut it I won't be able to turn left very far...
Reen I have 2 TA05R and didn't have to cut the chassis, different servo.
I would try different servo saver first.
TwoTone is offline   Reply With Quote
Old 01-05-2009, 07:02 PM   #602
cheehtae's Avatar
Trader Rating: 15 (100%+)
What CF chassis will fit the IFS r? I'm trying to search for Kawada chassis but no luck. Will 05 ms chassis fit?
cheehtae is offline   Reply With Quote
Old 01-06-2009, 10:28 AM   #603
The 05MS chassis won't fit; it is narrower than the standard 05 chassis with no mounting holes for the front cross member, therefore you won't be able to mount the aluminum posts for the front shock brace.
I have a Kawada chassis. It has mounting pattern like the stock, but the length of the posts do not much. I had to custom grind a lot of plastic off the IFS front shock brace and use proper shins to make everything fit correctly. It took some work, but is doable. Too bad Kawada discontinued that chassis.
Your easiest bet would be a 3Racing IFS conversion kit. That's made specifically for IFS, so fitting would be easy. Bad thing is, I don't really like the 3Racing's product quality...
But for the chassis itself, 3Racing would be a good choice.
Best regards~
dendog220 is offline   Reply With Quote
Old 01-06-2009, 10:55 AM   #604
reenmachine's Avatar
Trader Rating: 26 (100%+)
I didn't have to cut my regular TA-05, nor did the manual suggest I may have to. It's not mentioned in the regular IFS manual either. There's a different, bulkier servo saver included with the IFS-R. It uses metal bands instead of the plastic flex ring, and there's noticeably less slop, but you have to trim the tub to accommodate it.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 01-06-2009, 10:57 AM   #605
Just out of curiosity, why do you want to go to a CF chassis? I don't think there's any performance to be found there -- in fact, I've seen many people report that the car didn't perform as well with many of these conversions.
Pete Waydo
Old 01-06-2009, 01:16 PM   #606
I do that for drifting. Indeed, TCS races in parking lots doesn't need stiff chassis like this. And for indoor races, no matter how you convert your TA05, it's still heavier and less competitive than other high end cars. Doesn't mean that you can't go fast with a 05, just it's the fact that a chassis conversion still won't bring the TA05 to the 415 level.
However, because the 05 is a relatively heavy car, switching to kawada chassis did save me about 50g. And for drifting, that weight saving and extra stiffness is a noticeable plus.
Old 01-06-2009, 11:16 PM   #607
teddy_ifa's Avatar
hi im a filipino and working here in saudi arabia and i want to show my ta05 ifs-r with new graphite chassis kit and some ho-up parts. check the image of my ifs and i want you all guys how it looks my ifs and feedback...
Tamiya TA05 IFS-04012009_010.jpg   Tamiya TA05 IFS-04012009_009.jpg   Tamiya TA05 IFS-04012009_003.jpg   Tamiya TA05 IFS-04012009_002.jpg   Tamiya TA05 IFS-04012009_001.jpg
TAMIYA TA05 IFS-R* TAMIYA TA05R * FUTABA 3PM * SANWA M11X * SURGE CRUSHER DOUBLE HULL BRUSHLESS SPEEDBOAT * 3RACING * YEAH RACING * HOBBY WING * HPI * ORION * TRAXXAS REVO 3.3 * LRP * XRAY T2R PRO * THUNDER TIGER 1:5 NITRO MOTORBIKE *
teddy_ifa is offline   Reply With Quote
Old 01-06-2009, 11:26 PM   #608
over gear's Avatar
do lipos fit on the 3racing chassis without touching the mid pulley?
over gear is offline   Reply With Quote
Old 01-07-2009, 12:52 AM   #609
teddy_ifa's Avatar
im using my old battery (nimh). if it is good for the kit i make an order a lipos battery... thanks for the advice. how about my gearing im using a spur 100T and pinion 26T and a motor 5.5turn. please give an idea about the gearing, i have a 13.5turn motor and this 5.5turn motor (brushless).
Old 01-07-2009, 01:06 AM   #610
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Tamiya and Square has a blue aluminum servo saver i just dont know if it will work with any TA-05 chassis but from what i have seen its a lot narrower than the standard issue servo saver of the IFS-R
buboy28 is offline   Reply With Quote
Old 01-07-2009, 05:28 AM   #611
cheehtae's Avatar
looks nice pre, are you using it as a rally car?
Old 01-07-2009, 06:18 AM   #612
buboy28's Avatar
hi bradir, nice car just curious are you running on a paved tracks since your tires are a little bit diffrent treaded type not the slicks one oh and say hello to senyor sandrixx for me he he he
Old 01-07-2009, 10:21 AM   #613
Trader Rating: 17 (100%+)
Default Which spool
I have the IFS-R.
Which is the right spool?
#53877 and reuse stock 37 tooth pulley or #49493
billb60 is offline   Reply With Quote
Old 01-07-2009, 10:44 AM   #614
Originally Posted by billb60 View Post
I have the IFS-R.
53877 (TA-05 spool) but you can use neither the pulley that comes with it nor the stock IFS-R one. You need the 54023 DB-01 37T front one-way pulley.
Pete Waydo
Old 01-07-2009, 11:15 AM   #615
Herc Driver's Avatar
As far as lipos hitting the pulley, yes they hit it...I ordered the chassis, installed, was impressed at how nice it looked then put my battery in and was angry!
Obviously there are some ways to make it work...I used the associated battery cups spaced out a bit but didn't like it...went back to the tamiya chassis
Herc Driver is offline   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 09:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 11:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-05-2005 12:20 AM
SEO by vBSEO 3.5.0
