Old 12-21-2008, 11:32 AM   #586
inconceivable's Avatar
Originally Posted by reenmachine View Post
I want to gear an IFS-R to about 3.6 FDR for 17.5 racing. What spur/pinion combo has anyone used to do this? 74/42 (both of which I have) will give me 3.62, but will the range of adjustment allow it?
I'm running a 17.5 at 87/50 and it temps out at under 120. This combo fits fine and I think I even have a little room left.
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 12-21-2008, 02:52 PM   #587
reenmachine's Avatar
Trader Rating: 26 (100%+)
Great info -- thanks. I assume that worked within the standard motor mount's range of adjustability.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 12-21-2008, 06:03 PM   #588
cheehtae's Avatar
Trader Rating: 15 (100%+)
are you using any fan?
cheehtae is offline   Reply With Quote
Old 12-22-2008, 11:49 AM   #589
Yes, standard motor mount
No, not with my 17.5. I run a Speed Passion GT LPF V1.1 and the ESC is barely warm after 5 minutes. The motor gets to about 120, and I don't run a fan on it either, though I've thought of trying one on the motor. I run on outdoor tracks and with the temps here being 50-60 lately, it just doesn't seem necessary yet. Maybe this summer ?
Old 12-22-2008, 11:53 AM   #590
A quick side note, I ran with a friend this weekend (who also has an IFS-R) who was running 87/47 and down the long straight we seemed about even. I'm really not sure why, but thought it may be helpful. I may have had a "little" more top end, but not 3 teeth's worth ....
Old 12-22-2008, 07:16 PM   #591
cheehtae's Avatar
has any of you guys tried adjusting TB's for shock's in front? if so what length? I just followed what's in the manual.
Old 12-23-2008, 01:58 AM   #592
it's the same as adjusting the collar in your shocks. i only fiddle with it if my dampers collars aren't enough for setting the ride height that i need.
Minami is offline   Reply With Quote
Old 01-04-2009, 03:42 PM   #593
Finishing up my IFS-R with a Futaba S9551 steering servo...
Did everyone have to cut the tub as described in the manual to clear the servo saver? I will have to and I think that sucks. Is there a servo that avoids this?
Pete Waydo
Old 01-04-2009, 04:09 PM   #594
Magnet Top's Avatar
I need to purchase a spur for my TA05 IFS to allow a range of Final Drive Ratios from 3.6 all the way to 4.2 FDR.
Would using an 87 tooth spur allow pinions from 50 to 42 work ? Thanks , I am new to the chassis.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 01-04-2009, 04:22 PM   #595
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
hmmmmm i have this kit also but i did not cut the tub but what i cut is one of the ears of the servo btw i'm using the 9550 servo
buboy28 is offline   Reply With Quote
Old 01-04-2009, 04:25 PM   #596
Yes, you have to cut one of the inboard ears no matter what servo you use. It also says that you may have to cut the tub adjacent to the servo saver to allow full range of motion. On mine, if I don't cut it I won't be able to turn left very far...
Pete Waydo
Old 01-04-2009, 04:45 PM   #597
buboy28's Avatar
oh ok, i have not yet run mine just tested it on a car stand when i've put the electronics i might have overlooked that instruction regarding the servo saver
Old 01-04-2009, 06:48 PM   #598
cheehtae's Avatar
will the rear carbon dAMper stay for the regular 05 fit the 05 ifs r, if so what's the difference?
Old 01-04-2009, 08:56 PM   #599
buboy28's Avatar
it will fit, in so far as i know there is no difference at all regarding the rear carbon damper stay
Old 01-05-2009, 05:28 AM   #600
stitchy's Avatar
I have that servo...I just grinded the servo saver down a bit more for clearance.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
