Tamiya TA05 IFS
#557
hi guys, just would like to ask if anyone of you tried using silver can motors with this chasis and would it fit the motor mount, thanks
#558
#561
will this Lipo fit?
Hi,
I am considering getting a TA-05 IFS but was hoping that I would be able to fit some of my lipos.
The packs measure 137mm long, 44.2mm wide and 26.6mm thick.
Can anybody tell me if this would fit a TA-05 without any mods?
Thanks.
Thanks.
#563
#564
Can anybody measure and let me know?
#565
You shouldn't have any problems running any lipos in that chassis.
I have the IFS-R and run big 5K Core RC hardcase lipos with NO problems. My friend runs the Trakpower hardcase lipos with no issues at all, and another track buddy runs Orion hardcase in his...
#566
thanks for your help.
i wasn't sure if i would have problems fitting them under the rear bulkhead, maybe this problem only occurs with the TRF series chassis.
#567
Did you have to loosen the battery bar screws?
#568
In the TA05, the battery sits out in the open, so no worries about the bulkhead. As for the battery strap posts, their height is adjusted to fit different types of packs by using different spacers...
#569
#570
I dug around this thread a couldn't find mention of this ..... has anyone modified the 37T diff pulley for use with the spool ? It looks possible with not a lot of work. I ask because the 37T one way pulley is a bear to find (I have one on order from Hong Kong that is still a week or two out). I want to try the spool out while I wait and thought I'd ask as I can't be alone in looking for this item. By the way, I have the IFS-R.
