Old 10-01-2008, 02:18 AM   #496
what's unique on that particular center one-way when compared to other 18T center one-ways?
Minami is offline   Reply With Quote
Old 10-01-2008, 02:52 AM   #497
[[john]]'s Avatar
Trader Rating: 24 (100%+)
Well, I spent about an hour at the track today, The car handles fantastic for the kit setup, Minus the massive amount of front tow the manual gives.
Basically just put the car on the setup jig, And mirrored everything, So it was all tight and exact.
Handles great, Struggled with steering, So I will work on that during the race day on Sunday.
So, It is a bxtch to build, But handles superb on the track. I guess it can only get better.
Ciao.
HyperRC
Xray XB2 DE // XB4 '16 // RACEOPT MTS Tē // CRC XTi
[[john]] is offline   Reply With Quote
Old 10-01-2008, 03:36 AM   #498
Erwin lewi's Avatar
Originally Posted by nexxus View Post
The ifsr has it's own unique centre one way (18t) and with the front one way you use a Tamiya Durga front one way pulley not the one included.
OK thank You...
www.hobiland.net ,081-660-3518
www.multimakmurperformance.com
NA / standar jalur kiri
Turbo jalur kanan
NOS jalur paling kiri (bahu jalan)
Erwin lewi is offline   Reply With Quote
Old 10-01-2008, 07:49 AM   #499
ok....another build question here. trying to install the steering servo. im using a futaba S9450 digital servo and noticed that the ears of the servo is hitting the center rail of the chassis. can you guys picture what im trying to say??? any of you guys had this problem??? also did you guys ended up cutting away the outer part of the chassis for the servo saver to clear just like what the manual said?? thanks!
jun_1.8T is offline   Reply With Quote
Old 10-01-2008, 08:04 AM   #500
you have to cut the ears of your servo, not the chassis. isn't is indicated in your manual?
Old 10-01-2008, 08:34 AM   #501
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by Erwin lewi View Post
Dear all TA05 IFS R user..
I need to know , tamiya release front belt for using front one way / center one way?
because I used front one way with smaller front pulley the stock belt becomes loose, not tight, even I already adjust the front pulley on front bulkhead.
You have to get the 37T one-way pulley from the DB-01. That's the correct pulley to use.
If you used 36T pulley front and 37T pulley rear, your car would drive very weird because the rear wheels would be spinning slower than the front...
94eg! is offline   Reply With Quote
Old 10-01-2008, 08:55 AM   #502
nope....nothing was said on the manual about cutting the ears on my servo. but did any of you guys cut the outer part of the tub chassis to clear the servo saver when it turns??? that part was mentioned on the manual though. thanks
Old 10-01-2008, 04:38 PM   #503
[[john]]'s Avatar
It says in the manual to remove the lower ear from your servo.
What are you guys using for a spool ?
HyperRC
Old 10-01-2008, 04:49 PM   #504
BLUE 2's Avatar
Trader Rating: 23 (100%+)
Talking
Hi
I use this ( 53877 )
with this pulley ( 54023 )
See ya
Cars Offroad : TLR 22B- TLR 22B 2.0- TLR 22-4B- TLR 22T- TLR 22SCT- TLR TEN-SCTE 2.0
Cars Onroad : HB Cyclone TC - TRF 416X - Tamiya TA05 - Serpent s411 eryx 2.0
BLUE 2 is offline   Reply With Quote
Old 10-01-2008, 04:54 PM   #505
BLUE 2's Avatar
Talking
Hi
Yes i did mod the chassis to clear the servo saver ( i just cut a v into the side wall till it clears the servo saver )
See ya
Old 10-01-2008, 06:19 PM   #506
you have to cut those ears off. and also, check first if your servo saver hits the "outer part" of your tub. i didn't have to cut/shave mine 'coz my servo saver is not hitting the walls of my chassis.
Old 10-02-2008, 09:41 AM   #507
Barry White's Avatar
Does the NSX 2007 fit a regular TA05 or is it to low?
Barry White is offline   Reply With Quote
Old 10-02-2008, 10:19 AM   #508
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Has anybody tried using the Pan-touring bodies (200mm pancar) on the IFS? If so what bodies have you used?
YR4Dude is offline   Reply With Quote
Old 10-02-2008, 10:31 AM   #509
94eg!'s Avatar
It might work if you cut a hole in the hood for the shocks and shock tower. Plus you may have to switch to the IFS rear carbon-fiber shock tower, but I can't be sure...
Otherwise it's much too low. The 2007 hood dips down from the fenders, and that's what makes all the difference (in looks and fit)...
2007:
2005:
Old 10-07-2008, 10:28 PM   #510
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
I just got my IFS-r together. I have a Mamba Max 5700 brushless setup I am putting in it. I mounted the motor mount fine, but the ESC doesn't fit where it is supposed to go. Should I mount it on top of the servo? Where have you guys mounted yours? Any ideas and suggestions would be great. Pics will be helpful as well.
I will post pics soon.
SerpentCT4S is offline   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 09:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 11:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-05-2005 12:20 AM
SEO by vBSEO 3.5.0
