Tamiya TA05 IFS
#376
You are referring to #53928 all around?
#377
hi, i'm a starter so please be kind
ok, so i'm getting an IFS in the coming weeks and was wondering what are the pros and cons of the IFS over the regular TA05 or any chassis with upright shock mounting positions for that matter aside from being able to use shells with lower bonnets. i'm thinking about it's handling differences, if there's any.
thanks!
thanks!
#378
I run both but can't feel any difference between the two.
#379
The combination of the ifs front weight distribution (shocks in front of axel vs way behind) with the low slung bodies do make a difference. But if you use those protoform bodies, it doesn't really matter.
#381
I got the front one way drive from a TRF 415, can i use it on the IFS?
Didn't come with the manual, can someone share how to install the one way to the IFS. The bearing seems too big to hold the one way unit, are there any additional parts that is required for installation?
#382
Shadowless, I don't think you can use the TRF415 one-way, the TA-05 one-way is offset to one side and the TRF415 is more centered so if you use it will just chew up the front belt.
#383
The front end feels more responsive. Think of it as a shopping cart. If you have a six pack way in front vs putting it about a foot back. Which one will be easier to turn?
People will say about the extra weight that the pushrod assembly will give, but if you think about the weight you lose from the shock tower assembly, it's not that bad. Someone actually weighed all the parts, and the difference was less than 10g.
#385
really love the IFS!
#386
Regional Moderator
Yeah, the antenna wire is bundled. Its lightly zip tied right on top of the reciever. Its just a covered up by the other wires, but its there. With the Futaba FASST system, I could bundle the whole thing and not have anything sticking up, and STILL not glitch, but I'm still a little old school, so I have to keep just a little nub of an antenna.
#388
Depends on what your running. If your running rubber tire, not only is the upgrade not worth it, but it may actually hamper your rubber tire setup by making the car too stiff.
If on the other hand, your running foam/carpet, then I would definitely say its worth it.
This is what I learned from my years with the TA05, so I assume the same will hold true with the IFS.
It's not too stiff and hangs nicely with the CF cars using 13.5 or 4.5 motors and a front spool.
#389
yeh believe this car here was set for all yellow and a spool, that was enuff to take TCS. not bad for a car that came only couple days before. good thing dont have to run on tamiya tires each wk. the track would fold if they did lol
R
R
#390
okies,
here is a list of stuff you need to get if you are converting from ta05 to ta05 IFS; exclude all the red items if you own a ta05R cos you already have those parts in your kit.
- N-part = 51294, can be replaced with reinforced N-part = 53991 (you will need to get 4 850 bearings for the rocker arms unless you get 53993 which comes with bearings)
- F-part = 51293 (trust me, its not the same)
- C-part = 51296 (trust me, its not the same either)
- 3x9.5 step screw, comes in a pair = 9805840
- rocker nut, comes in a pair = 9808126, can be replaced with aluminium rocker nut = 53992
- aluminium rocker arm set (for bling, cos you get real good and stiff rocker arms with 53991) = 53993
- carbon rear shock tower = 53994 (also for bling)
- LW reversible arms (your choice, hard/soft/short/long) and corresponding axles (ta05R owners already have these arms).
- E-part = 51298 (ta05R owners already have this)
- 2 3x0.7 aluminium spacer (from wherever, you can get this in a pack of spacers or singly)
- 2 28mm turnbuckles
- 2 4.6x4.7 flange tube (for the steering knuckles) = 51100
- 2 4.5x3.5 flange tube (for the steering knuckles) = 9808021
- 2 5x8 ball connector (for the steering knuckles) = 53969
slap them together and you will have a TA05 IFS!
good luck!
-alexander
p.s. dunt bother with the alloy steering hubs as you will spend a minor fortune on replacement bearings... non of the parts you listed are neccesary, only the ones in my list.
good luck!
-alexander
Sorry to bring out this old post for the standard 05 to IFS conversion.
I have 2 questions:
1. Can I use 2 3x32mm turnbuckles instead of the 28mm? (Read the IFS-R manual and they are using the 32mm)
2. The IFS-R is using 54031 for the F parts and 51332 for the C parts. Which should I follow? The part numbers as suggested by foampervert or the manual?
Please enlighten. Many thanks.
