Old 06-30-2008, 02:47 AM   #316
gdbdhb's Avatar
Originally Posted by sammz_987 View Post
has anyone used the 3racing carbon fibre lower deck for the IFS? is it good? or anybody know if Tamiya has come out with their own carbon fibre deck? i heard rumours that they(tamiya) already came out with it in Japan.
I have been using the 3 racing carbon fibre chassis for a while now, I LOVE IT. I bought the kit here in Australia and have only had one problem.The alloy rocker arm pivot points bend when you have a crash. To fix this i have made a carbon fibre brace that goes between the arms and i just screwed it in the top, Works a treat. I will post photo's soon to show you.Hope this helps.
gdbdhb is offline   Reply With Quote
Old 06-30-2008, 04:54 AM   #317
TryHard's Avatar
Originally Posted by adrictan View Post
Putting 2 front one-way for both the front and rear, will it be good for drifting? Does that mean I won't be able to reverse?
Won't work... as to get the oneway to fit in the rear, you'd have to flip it over, which would mean the rear one runs in reverse (Freewheels under power, locks up off power), which would give FWD on power, and RWD off power
If you want to drift it, try as the guys have said, a spool in the rear, with the one way up front... that will make the rear step out no end
HiH
Ed
Old 06-30-2008, 05:47 PM   #318
adrictan's Avatar
I've installed the spool for the rear. Well, the car rear wheels still lock up when I release my throttle. At first my frds thought my spur/pinion were placed too close but I've adjusted, no use. Belt tension is ok. Think I'll check my center pulley....
adrictan is offline   Reply With Quote
Old 06-30-2008, 05:52 PM   #319
check your drag brake on your ESC
Or check your bearings.
Or check your rims, make sure they aren't binding with the ball cups.
DirtyRacer is offline   Reply With Quote
Old 06-30-2008, 06:57 PM   #320
adrictan's Avatar
I've checked the wheel hubs, dogbones, spool, belt, center pulley. All seems fine. ESC I've done the reset and start up again. Transmitter setting, I've done all the checks. Still, I think it's the ESC or Transmitter. Maybe my motor. Ha! Bummer..
Old 06-30-2008, 07:05 PM   #321
Core Creations's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to Core Creations
Try giving it a little creep (forward throttle trim) maybe 5% and see what happens.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 06-30-2008, 07:24 PM   #322
adrictan's Avatar
Thanks. Have just tried that. Same same....Mayb I'm dumb. Ha!
Old 06-30-2008, 07:28 PM   #323
remove the dog bones and see if the rear tires spin freely.
edit: are you running brushless? lipo?
Old 06-30-2008, 07:38 PM   #324
adrictan's Avatar
It's definitely nt the dogbones cause I tool the rear belt off the center pulley and pull. Rear spins fine. I took the dogbones off the spool and pulled the belt. It still has the tension.
Old 06-30-2008, 07:40 PM   #325
maybe you can't drive
Old 06-30-2008, 07:52 PM   #326
adrictan's Avatar
Thanks for the sarcasm.
Old 07-01-2008, 12:57 AM   #327
TryHard's Avatar
Sounds an odd one... What exactly is happening?
You say you've checked;
Wheel bearings
Axle Bearings
CV joints (make sure the pin isn't partly out)
Diff
Wheels (make sure they aren't catching on anything)
ESC settings
Transmitter settings
Centre pulley bearings.
Best thing to do is start from scratch, and work through in a logical manner to see what the issue could be. Start with the rear hubs, then rebuild the car up, testing each link in the drivetrain in turn, too make sure it doesn't bind.
By the way, what ESC/Motor are you using?
HiH
Ed
Old 07-01-2008, 07:09 AM   #328
adrictan's Avatar
I'm using Futaba MC330CR & Team Orion 18T motor.
Old 07-01-2008, 07:22 AM   #329
TryHard's Avatar
are you testing it with the car on a stand, or out doors on the ground (ie, no load vs loaded).
If it's on the stand, then the wheels will stop quickly, simply because there is no momentum keeping the drivetrain moving... best to try it on the ground first.
HiH
Ed
Old 07-01-2008, 07:51 AM   #330
adrictan's Avatar
Tested on ground and while holding it.
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
