Old 06-23-2008, 06:25 AM   #286
Originally Posted by Qatmix View Post
thanks,
when you say drive pins, what part no's do you mean?
The pins at the end of the dog bone. The slot in the al diff is much wider than that in the plastic diff (stock or precision) and require the use of the cushions or else you will ruin the diff outdrives.
If you do decide to go with the al diff then buy extra cushions, you will need them.
AreCee is offline   Reply With Quote
Old 06-23-2008, 06:29 AM   #287
Originally Posted by buboy28 View Post
if you are going to buy the aluminum bulkhead you can only use it at the rear of the IFS, front bulkhead of the IFS is different from the original TA-05, R and MS
You can use the regular TA05 al front bulkhead and not use the shock tower screw bosses, it will only look weird with the body off but only to those who know the difference.
Tamiya and others do make a front bulkhead without the shock tower screw bosses.
Old 06-23-2008, 09:25 AM   #288
adrictan's Avatar
Guys, I have a problem. I have a IFSR and I've just installed the new front one-way. However, when I want to put back the one-way to the chassis, even though I've adjusted the mounting parts (A11 & A2), the belt is much looser compared to when I was using the ball diff. Anyone has used the front one-way on the IFS yet?
adrictan is offline   Reply With Quote
Old 06-23-2008, 10:48 AM   #289
94eg!'s Avatar
Trader Rating: 17 (100%+)
The pulley that comes with the TA05 one-way is 36T. The IFS-R comes with 37T pullies. You need to get the Durga 37T one-way pulley to make it work like before. Otherwise your front wheels will be turning slower than the rears...
94eg! is offline   Reply With Quote
Old 06-23-2008, 11:40 AM   #290
Sorry to be a pain, but what part no's are they.. I'm a bit confused still as to what you mean..
Qatmix is offline   Reply With Quote
Old 06-23-2008, 02:08 PM   #291
94eg!'s Avatar
The original TA05 pulleys only had 36 teeth. The IFS-R's pulleys have 37 teeth. To compensate for this, the IFS-R's belts are slightly longer than all other TA05's. This means that if you try to use the 36T pulleys, the belts will be loose.
You must get a 37T one-way pulley because the TA05 one-way comes with the older/smaller 36T...
This is what you need:
Old 06-23-2008, 08:37 PM   #292
adrictan's Avatar
The dumb Tamiya USA emailed me and told me all TA05 parts can be used on the IFSR.
Old 06-23-2008, 09:50 PM   #293
They are correct, you can use all the TA05 parts on the IFSR but you may need to use additional items to make it operate properly. Do the research, ask the right questions and you'll get the best results.
From your pictures of your build it looks like you don't follow instructions well and I'll bet you do not ask well phrased question either.
Do what I do, download the TA05R manual and compare part numbers, that way you'll see if it will be the one you want and if you need another item instead.
Old 06-23-2008, 11:50 PM   #294
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
why email dumb Tamiya USA when the local Tamiya agent Stargek is just a phone call away or a visit to their shop whereby you'll be served by knowledgeable staff (read racers)???
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 06-24-2008, 07:14 AM   #295
adrictan's Avatar
Lesson learnt...
Old 06-24-2008, 08:22 AM   #296
Yep, there's a big difference in these questions:
Can I put a TA05 one-way in an IFSR?
or
WIll the TA05 one-way work properly in an IFSR?
The answer to the first is, YES.
The answer to the second is, Yes but you will need a new belt.
Old 06-24-2008, 08:36 AM   #297
hehehe....thats a good one.
btw, i tried to upload some pics of my hopped-up TA-05 IFS but was prompted that the size is too big. is there any way that i can post it w/out resizing to a smaller size?
sammz_987 is offline   Reply With Quote
Old 06-24-2008, 08:41 AM   #298
94eg!'s Avatar
...The answer to the second is, Yes but you will need a new belt.
You mean a new pulley! You don't want have a smaller front pulley do you?
Old 06-24-2008, 09:08 AM   #299
adrictan's Avatar
Alternatively I can use the original 37T pulley and attach the one-way to the belt. It'll work too.
Old 06-24-2008, 09:53 AM   #300
Yes, you're correct. I was merely showing an example of the difference wording makes in a question to receive more information.
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 09:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 11:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-05-2005 12:20 AM
SEO by vBSEO 3.5.0
