Old 06-03-2008, 09:12 PM   #256
atomapapa's Avatar
Trader Rating: 92 (99%+)
Originally Posted by Core Creations View Post
My IFS-R will be here tomorrow...here's a question to those that know...Will the original front spool and Oneway from the original 05 work with the new diff pulleys?
Yes. Just buy 501x or 416 pully and use original TA05 spool or oneway work no problem
atomapapa is offline   Reply With Quote
Old 06-04-2008, 12:02 AM   #257
Trader Rating: 26 (100%+)
i've seen ifs-r for sale at muchhobby.com (canada), rc-champ.co.jp (japan) and stellamodels.com (hk).
Tamiya TRF416
Tamiya TA05-R
XRay T2 '007 EU
Mini-Z Parts Bonanza
http://www.rctech.net/forum/showthread.php?p=4709247
limbohz is offline   Reply With Quote
Old 06-04-2008, 03:00 AM   #258
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by adrictan View Post
Which one is the C-hubs and steering knuckles holes?
Racing4Evo is offline   Reply With Quote
Old 06-04-2008, 04:45 AM   #259
pug 205 gti's Avatar
When building a car it always pays to read the instructions thoroughly first.
To avoid the aviodable,Piss poor planning gives piss poor performance.
Its quietish on rctech lately?
pug 205 gti is offline   Reply With Quote
Old 06-11-2008, 10:41 AM   #260
adrictan's Avatar
Need help. Can anyone post instructions on how to lock the rear for the IFSR or is there any part I can buy to change to locked? Also will the TA05 front one-way fit the IFSR as well?
adrictan is offline   Reply With Quote
Old 06-11-2008, 10:50 AM   #261
you trying to drift the car?
Just get a spool and install in the rear.
redbones is offline   Reply With Quote
Old 06-11-2008, 10:53 AM   #262
adrictan's Avatar
I know this sounds dumb but any pics of what a spool is? If ther's a part number or website pic would be great. Thanks/
Old 06-11-2008, 12:11 PM   #263
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
FYI -- Speedtech just got the IFS-R in stock.
http://www.speedtechrc.com/store/ebp...alpage=special
Turbo Joe is offline   Reply With Quote
Old 06-11-2008, 12:13 PM   #264
Turbo Joe's Avatar
It's a solid front axle...no differential.
http://www.speedtechrc.com/store/ebp...id=459&id=5802
Old 06-11-2008, 01:57 PM   #265
Any car with the name TA05 (including the MS) uses the same diff front and back. So if you buy a front oneway for the TA05, it will work on the IFS as well. Same for the spool. if it works on the front, it will work on the rear.
Old 06-11-2008, 02:52 PM   #266
mwampoki's Avatar
Rangerwalker,
If you are going to race that thing, be sure to change out the brass rings in the front suspension and in the steering for bearings. I believe the 5X8mm is the size that you want. It drastically increases the smoothness of the front suspension and your steering response. I found the car to be much smoother and easier to control with the bearings.
Looks like you have done a good job! Just be sure to switch what has already been pointed out and be sure to let us know how it runs when you take it out for a spin! These cars run REALLY well when you get them set up properly, and as a plus, they take ALOT of abuse on the track!
Best Wishes!
mwampoki is offline   Reply With Quote
Old 06-11-2008, 06:03 PM   #267
adrictan's Avatar
Can confirm the diff are the same for TA05 and IFSR?
Old 06-11-2008, 06:12 PM   #268
Kevin CBR's Avatar
Diff outdrives are the same. IFS-R uses the 416 pulley and diff plates.
Kevin CBR is offline   Reply With Quote
Old 06-11-2008, 08:09 PM   #269
adrictan's Avatar
OK. I suppose I should get the TA05 Front One way to put then. Right?
Old 06-12-2008, 12:38 AM   #270
http://rcmarket.com.hk/product_info....oducts_id=2800
you are probably going to need this also.
maybe two if you are going to use the spool for the rear as well.
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
