Old 05-26-2008, 08:04 PM   #211
Originally Posted by RangerWalker View Post
-So you did not use glue on these rings,only sanded them?
Glad to read that the car is performing OK.
How about using RED Loctite only if ya gonna use them Alum outdrives to hold the diff rings together guys?
Of coz letting the parts cure before assembly.
Just a thought guys..
Any comments?
theEdge is offline   Reply With Quote
Old 05-26-2008, 08:46 PM   #212
Peter_PaP's Avatar
Some new bodies.
I think i found my first shelf queen (the Eclipse)
DB01 Durga
TA05 Esso Ultraflow Supra
Spectrum DX2.0
LRP
Peter_PaP is offline   Reply With Quote
Old 05-26-2008, 10:29 PM   #213
adrictan's Avatar
So the Spur must remain 105T while the Pinion can be changed?
adrictan is offline   Reply With Quote
Old 05-27-2008, 12:19 AM   #214
adrictan's Avatar
Any in SG who has done up their IFS-R and using for drifting? Wanna ask things easier.
Old 05-27-2008, 02:17 AM   #215
adrictan's Avatar
So I can change the stock 105T to a different spur? 60T or 70T?
Old 05-27-2008, 02:25 AM   #216
adrictan's Avatar
  • Does tht mean IFS-R die die must use 105T spur?
  • Lowest FDR according to the chart is Pinion 47T to reach 4.59:1.
  • So with 47T, I'll have the fastest acceleration possible but a low top speed?
Old 05-27-2008, 04:49 AM   #217
It comes with a 105T .6mod gear in the kit. You can change it to anything you want; 32, 48 or 64 pitch and any size that will fit. Those choices are up to you.
Depending on your motor a 4.59 FDR will give you slower acceleration but higher top speed and can burn out a motor by overheating it.
AreCee is offline   Reply With Quote
Old 05-27-2008, 09:28 AM   #218
adrictan's Avatar
I went Taroda after work today. The guys there were pretty nice and spare parts quite comprehensive. Anyone here has assembled his TA05 IFS-R?
Wanted to assemble mine just now but after putting the motor mount to the chassis, the next step needs cement which I didn't buy. So I ended up doing the TRF damper shocks only. Sucks...
Somemore the 1st pg also indicates must cut 3 parts of the chassis to prevent the belt from hitting them. I don't have dremel.
Can don't cut away?
Old 05-27-2008, 10:08 AM   #219
You can sand the outdrive and diff ring so they can grab on to each other. The pressure will prevent them from slipping. And yes, I highly recommend shaving that area that the manual says to. The belts do rub on that area slightly. If you don't have a dremel, just use a side cutter and xacto blade and be creative.
redbones is offline   Reply With Quote
Old 05-27-2008, 10:13 AM   #220
adrictan's Avatar
Sigh..Then I must go find sandpaper...So sand the outdrive & diff ring until what condition?
The parts that seemingly needs to be taken off seems pretty tough plastic. I think I will put the belts then see exactly where I need to take away. Anyine in SG can guide?
Old 05-27-2008, 10:24 AM   #221
Don't sand so much that you warp the outdrives. get like 600grit paper and "scuff" the outdrives. For the diff ring, just do it like you normally sand one, but do it on both sides instead.
Old 05-27-2008, 11:07 AM   #222
adrictan's Avatar
So after sanding both parts, I clean off the shavings and just attach them without using any super glue or cement? Most of the other forums' postings did not indicate putting any after sanding.
Old 05-27-2008, 11:55 AM   #223
adrictan's Avatar
My 2 problems. Basically is where exactly to cut and how much to cut. And also whether or not to apply the rubber cement as according to the manual to the Diff plate and diff joint or just sand paper as recommended in many forums.
Old 05-27-2008, 02:17 PM   #224
Trader Rating: 26 (100%+)
Default FDR 2.25 to 2.055
to convert the internal ratio of a ta05 ifs 2.25 to the ifs-R 2.055 (or 416 type), what do we need to do aside from replacing the:
center pulleys
diff, one way & spool pulleys
diff bearings
center plate
someone said we have to replace the belt as well?
would anyone have any info on this? also, the part number for the aforementioned items?
thanks in advance
Tamiya TRF416
Tamiya TA05-R
XRay T2 '007 EU
Mini-Z Parts Bonanza
http://www.rctech.net/forum/showthread.php?p=4709247
limbohz is offline   Reply With Quote
Old 05-28-2008, 04:33 PM   #225
housey's Avatar
hey guys, been out of the RC scene for about 18 months but now i really fancy picking up an IFS-R, but at the moment iv seen about 10 pics of it and they all look like they have different parts on them (alu bulkheads and rockers, graphite bulkheads and rockers etc etc) and iv seen ones without hex drive screws, do they really ship an R kit with crappy cross-head screws?
anyways i was just wondering if anyone knows exactly wots in the R kit when compared the standard kit, cheers guys
housey is offline   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
