Old 04-13-2003, 03:54 AM   #1
diesel's Avatar
Default Saddle Pack Assembly
Hey guys, do i need to apply glue between the batteries when assembling a saddle pack? Are there any other ways in binding the batteries firmly? How much glue do i need to apply so that there isn't any space in between the batteries? Sorry for the questions...pretty much a newbie in assembling cells.
diesel is offline   Reply With Quote
Old 04-13-2003, 03:55 AM   #2
Cole Trickle's Avatar
I dont glue my saddles. A pack I bought assembled, was glued from the matcher. But the glue didnt last for long...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-13-2003, 04:01 AM   #3
LouisB's Avatar
You can use Shoe Goo to stick the cells together.
I use single cell heatshrink on all my packs and then I use CA to glue them together. When they get messed up you can just take off the heat shrink and start over again
Some people put a bead of hot glue between the cells after building the pack, I found that the glue fell off after a race or 2.
LouisB is offline   Reply With Quote
Old 04-13-2003, 05:26 AM   #4
I'm with LouisB... Shoe Goo works great... and you should definitely glue your saddles together... otherwise your batt bars might bend outwards due to the weight of your batts (if you aren't careful with handling your packs)
jwwu is offline   Reply With Quote
Old 04-13-2003, 11:19 AM   #5
Registered User
Use clear silicone II. It is permanently flexible, and heat below 400 F.
Aku-Man is offline   Reply With Quote
WTB saddle pack lipo's for b44 joyride153 R/C Items: Wanted to Buy 0 02-15-2008 04:28 PM
WTB Saddle Pack Platinum_Racing R/C Items: Wanted to Buy 1 12-03-2005 09:30 AM
battery pack assembly (help sites) unknown Electric On-Road 7 02-12-2003 12:08 PM
SEO by vBSEO 3.5.0
