Old 05-13-2007, 04:30 AM   #1
rcstunt101's Avatar
Trader Rating: 16 (100%+)
Default Novak GTB + brush motor capacitors
Im just wondering, in the novak gtb manual for running in brushed mode it says : The ESC can be damaged if the proper type and number of capacitors are not used. Three 0.1F (50 V) capacitors MUST be soldered on EVERY motor connected to the ESC (unless they are already in the motor); one from the positive motor brush tab to the ground tab; one from the negative motor brush tab to the ground tab; and one between the positive and negative motor brush tabs.
I am running brushed mode with a CO27 based stock motor and just wondering are these three 50V capacitators built in? I have been running the motor and esc for about a month without them so my guess was that they were built in on motor.
Associated TC5R
Associated B4
Yokomo B-max4
LRP, Intellect, Futaba
rcstunt101 is offline   Reply With Quote
Old 05-13-2007, 05:19 AM   #2
Bdegan's Avatar
Yes, The caps are built in. They are mounted on the little PCB board on the end of the endbell.
Bdegan is offline   Reply With Quote
Motor Capacitors Zagar Radio and Electronics 1 04-07-2008 08:59 AM
NOVAK New XBR Sport Brush/Brush Speed Control rcforum Electric On-Road 42 09-03-2007 11:45 AM
what motor capacitors? noobie Electric On-Road 3 03-15-2006 06:26 PM
Motor capacitors Hologram Rookie Zone 9 07-27-2005 02:16 AM
Novak GT7 capacitors ChadCapece Electric On-Road 12 11-03-2004 06:26 PM
SEO by vBSEO 3.5.0
