Li-po pack= slow car?! help!
#17
Originally Posted by B18C Turbo
uhhhh I garuntee that these cells are as good quality as the stuff Orion or Maxamps uses just without a label. Im not sure what the C rating is, i emailed the seller and if I remember right it was a 20C, im not sure positive but what does that mean?
C rating is how fast you can discharge them. Higher C rating means you can pull higher continuous amps from the cells without damaging them. When you draw more amperage from them than you should, they get hot, voltage drops, and they get damaged.
#18
Those batteries might be good in some slow flyer who wants to get get 3/4 hour flight time with a low amp motor. Makes my neck hurt thinking about it.
#19
Originally Posted by Scottrik
Ummmm....'cause they actually work?
They will work better ....
#20
#21
Used my Team Orion/Peak Racing 3200 and 4800 on my F103GT/TA05R with 10X3 and 4.5 BL.........tab the throttle and cars bang to the door (running in my basement with carpet....big mistake).......batteries is as good or even better then matched IB4200WC.......except, last alot longer and less work.
So I think it is the batteries..........another reason why buy name brand product, you can get TECH SUPPORT (here on Rctech) or call them if things go south....just here in Rctech, several Team Orion representative are answering question and taking care of customer support...
Try ask the customer support thru EBAY or that no brand name battery place in CHINA.....
#22
I will not go into the obvious as others have already, but I will offer possible solution t your problem. It sounds like the cells have gone out of balance.
I would balance them and see if your performance goes back to where it should have been. If not then I would listen to what others have said as they appear to have done things differently and had a much better experience.
#24
Originally Posted by syndr0me
The cells are triple the quality, and over triple the safety. I would strongly suggest you take some time to educate yourself about LiPo before doing anything else with them. If that seems like too much trouble, you may want to stick with NiMH. There is no bargain with cheap LiPo, just danger and lackluster performance.
Stop what you're doing and read every page of this thread. Then, properly dispose of that cheap LiPo you bought and save your pennies for a quality pack.
http://www.rctech.net/forum/showthread.php?t=154155
#27
Originally Posted by seth556
I would get some maxamps or trackpower li-po batteries. They are the best of the best. Orion is good but they charge a lot because of the well known name. You can get a lot more for your money.
#28
The C ratings for everybody is basically a lie.
The lipo world is still in it's infancy, and the marketing guys are having a field day. Everybody is trying to outdo the next guy with the claims..... "my C rating is bigger than yours".... And as we all know, the first liar doesn't stand a chance.
Everybody claims a "constant" and a "burst" discharge rating. Completely ignore the "burst", and use the "constant" rating as the actual "burst" and knock the claimed "constant" rating in half. That's much closer to reality in my experience.
rcgroups.com has a huge sticky thread in the battery subforum with independant tests on a bunch of different manufacturer's lipos. Might be worthwhile to do some reading......
#30
Originally Posted by bxpitbull
Dont be dissing MaxAmps packs, they rock. My 6000 by MaxAmps is still going strong. Kokam is probably the best out of the gate however.
If I needed more capacity than 4800, I'd go with MaxAmps for sure, but I wouldn't have any false hopes about how they compare to other cells. Getting what you pay for is okay if you're realistic about it.
