Funky tire wear...
Funky tire wear...
I've raced 3 different touring cars as of now, and they all get some sort of ridge on the inside of the front tires. My Cyclone S managed to cut through one of the tires in a race day (read=maybe 30 minutes of real running).
What causes this?
here's a pic of what I'm talking about:
Check out the inner fronts.
I've run mainly CS27s on my cars...is it a tire thing?
What causes this?
too much front camber
thats the only pic of my old XRAY that I have, but my Cyclone S is doing it also, but a LOT worse.
im looking at the car now, and the inside of the tires are quite a bit smaller than the outside on all four ends. the rears have a tick smaller ridge though. could be a camber thing, as this was setup for carpet after all...
but i'll keep toying with it, and chiming back in with progress (if any)
Id throw it on a setup station and see how much negitive camber you have on the front and back, my guess would be it's more than -2 wich is the most you should ever need. Also while it is on there check the toe out in the front, I have +1.5 which is a little high, it is usually around +1 in the front and -3 in the back.
Check camber, but I'd say it is the front wheels have too much toe in. It used to happen to me alot. When I toed the front wheels out a bit, no more radical tire wear. With too much toe in, the tires fight each other when turning in to corners. Just turn the steering all the way to one side and see that the outside wheel is turning in while the inside wheel doesn't turn as much when it should be turning more. Ackerman related problem.
CS27's are kind of notorious for getting that ridge when there's too much camber. They even do it a little bit when you have the right camber. It comes from the amount of tire squirm you're getting. The carcass is literally folding over. Check your camber (make sure it's around 1 to 1.5 degrees) and toe settings (try and set it as close to 0 as you can) and toss a set of RP30's on it.
I've just burned through two sets of RP30's. one set per 5-race club meet. I doubt I will buy them again, or at least, not for club/weekend racing, I was seeing canvas after four runs.
Must say the RP30's give great grip and handling compared to a CS27 though!
It could also be that your inserts are too soft and that they are not giving enough support to the tire which can cause this wear. Are these tires you're mounting yourself or are they premounts, I do not recognize the rims. Please take other pics of either car and give more info on your tire combos.
Steve
Steve
I always get this too when running rubber on tarmac. Unfortunately I only race on tarmac infrequently so haven't worked out exactly what is happening.
I think the suggestions of too much steering lock and too soft an insert are probably valid.
But I also think that too little camber may be a factor, not too much. If you look at the wear it is as if the tyre is folding in on itself, rather than just wearing around the inside. With more negative camber the tyre should be more evenly loaded mid-corner.
I also wish more manufacturers would make inserts that "fill" the tyres again. These low profile inserts may give good traction but they don't help with wear at all.
I hope these pics are good enough, dont think the powershot is doing its thing...
here is the Cyclone...
These are the 27s (take-offs premounted)...
I'm missing a knuckle as it was absolutely destroyed last time I ran it, but front toe looks to be at or close to 0.
