TC3 Motor size question
Can you fit a 28mm(I think thats a 380 size) on a TC3? or would it require an adapter plate..or not fit at all? I'm not here to debate how well it'll go. I just can get a free BL 28mm 4900kv brushless motor and figure it would be good for my daughter to drive around if it'll fit.
An Adapter even if it fit will be more expensive than just getting a Johnson/Mabuchi motor (under $10). Not trying to discourage your project, just mentioning this if cost is the underlying reasaon
Actually its my luck. This 380 motor has mounting holes the same as a 540! what luck.
