Old 04-24-2007, 08:51 AM   #1
Default help me find my gearing
On an custom works intimidatior? Just what are you running? Track size, tire size, anything else?
Im runnin foam tires, do know the Dia yet, have to true
10 turn fantom motor
96 spur
235 line track, wide sweeping corners.
need pinion. Is there a mathematical equation to it?
derricklong38 is offline   Reply With Quote
Old 04-24-2007, 09:13 AM   #2
Elboogie's Avatar
I use to have a problem with my gearing on my track as well. What i did was find out what my final gear ratio for my car was. Once I found that out i went to a website that has a rollout ratio (use web search). The formula will allow you to put in your tire diamater (mine is 58mm using foam tires) and then it will allow you to put in a spur and pinion.
I run 19 turn motors because our track is too small for mod but on 19 turn motors it was recommended to me by my car manufacturer that I should be running between a 6.2 and 6.3 gear ratio.
so the final inputs on my car is a 58mm tire, 100 tooth spur gear and 39 tooth pinion on a Komodo dragon pro and my car flies. I hope that this helps you out and I hope that I answered your question.
Jaco / Airtronics
Much More / Team Orion
"Drive Hard or Go Home"
Elboogie is offline   Reply With Quote
i cant find... mr_race Rookie Zone 4 11-28-2007 09:20 AM
Can't Find!!! $rusty$ Electric On-Road 2 11-30-2006 04:33 PM
Where can I find this? sho .21 Electric Off-Road 1 11-26-2005 01:12 PM
OT Can any one help me find HALFFAST Electric On-Road 0 11-03-2003 10:41 AM
find gd car BeCk Singapore R/C Racers 7 06-13-2003 11:11 PM
SEO by vBSEO 3.5.0
