battery building
battery building
what soldering iron do u guys use to build batts? ive got a weller thats pretty good but its starting to lose some of the temp. im looking for one that gets the item hot quick. are the 936 very good at building batteries? thanks for the help
Registered User
I use this iron which is 40W/900 degrees, 1/4" chisel tip, and it's inexpensive. I have one just for soldering batteries, this thing works awesome.
Choose by the tip size as much (if not more) than the wattage. For example, the Weller Soldering Gun is 120w, but the tip is so small that as soon as it touches a cell all the heat is pulled away. The Weller suggested by Desolas has a lower wattage but a large tip.
The trick with cells is to have a lot of heat stored in the (large) tip so that when you put it on the cell, it heats the joint and doesn't just drain away. Also, using a paste flux (NOT a liquid, acid flux) ensures that the solder flows fast and all across the joint - another way to minimise the time the tip needs to spend on the cell.
Weller make some great irons for the job, of which this one is the pick of the bunch. It is designed for stained glass leads, which suck out heat like a hungry tiger! HTH
FWIW-I use RS #64-015E High-Tech Rosin-Core Solder instead of silver solder. It flows at a lower temp and dosen't dirty up the tip as much. The RS #64-022 Non-Spill Paste Rosin Soldering Flux and RS 64-020D Tip Tinner and Cleaner work well too. BTW-wet your soldering sponges with distilled water-it has less contaminates and wipes the tip better than tap water.
Hope this helps.
Arnie
I use this one http://www.hmcelectronics.com/cgi-bi...i?query=wesd51 it has a digital temp readout, but there is a little bit cheaper version pictured right below it http://www.hmcelectronics.com/cgi-bi...gi?query=wes51, I have used a couple different soldering irons and this is by far the best I have used for battery building. If you get one of these you will need the ETD tip wich is the lage chisel style, works best for battery building.
100W iron
and just a little solder.
and a heatsink on the bar when soldering.
