Old 04-21-2007, 02:31 PM   #1
bozla's Avatar
Default RC car design
Are there any articles online, or any books that anyone would recommend?
bozla is offline   Reply With Quote
Old 04-21-2007, 02:54 PM   #2
Trader Rating: 26 (96%+)
Heres the simplest way to do it if you actualy plan on building your car.
step #1-
Find all the parts that are standardized off other cars. You aren't going to re-invent a belt and pully or shocks so figure out what you want and use that.
step #2-
pick out a good 3d cad program and put the objects your using in cad w/ the apropiate measurements taken so that the car will assemble well.
step #3-
The main pieces that need to be ultra precise should have adjustable mounting locations so that you can make sure everything lines up right such as the distance from a front diff to a rear diff if your making a 4wd car similar to that of nitro engines.
step #4-
keep in mind that your going to have to have these parts built, the simpler the parts the easier it will be for you to have it built in a machine shop.
step #5-
There is know way to know how it is going to truly perform with everything in it so build it to be adjustable.
party_wagon is offline   Reply With Quote
Old 04-23-2007, 04:47 AM   #3
Send a message via ICQ to elvo
elvo is offline   Reply With Quote
Old 04-23-2007, 04:58 AM   #4
Trader Rating: 35 (100%+)
Race Car Vehicle Dynamics by Milliken
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
YTM Design yourtheman Painting, Designs, Graphics and Photography 1 04-13-2008 01:22 PM
R/C Web Design elmo6s R/C Items: For Sale/Trade 0 09-25-2005 10:24 AM
Web Design/Ecommece Design MaxxFusion Web Links 1 08-03-2005 07:19 AM
3-D car for design mikecatts Painting, Designs, Graphics and Photography 4 06-19-2004 04:00 PM
IronCAD Design Software for SALE - Design your own parts! morosis Other Items: For Sale/Trade or Wanted to Buy 5 09-03-2003 07:41 PM
SEO by vBSEO 3.5.0
