Futaba 9602
Old 04-20-2007, 06:15 PM
surrealmaterial's Avatar
Default Futaba 9602
Hey Guys,
im in the middle of searching for a new servo and im thinking of getting the Futaba 9602 servo......although is this a metal geared servo? And has anyone had any problems with them?
Cheers
surrealmaterial is offline
Old 04-20-2007, 07:33 PM
TEM
TEM's Avatar
Originally Posted by surrealmaterial
Hey Guys,
Cheers
I have 2 of these. The older one must be 7 years old and worked as good as it did when new. Used them for 12th scale. I had one in a touring car to save weight in a non weight restricted class and it held up just fine! They are very fast and rugged. Metal gear, ball bearings and coreless. The only single thing I heard bad was from oval guys saying "Oh, you wouldn't want that in oval, you want something digital"...... Thats kind of hearsay.... Get one!, you won't be disappointed!
TEM is offline
Old 04-20-2007, 07:34 PM
what about the futaba 9402?
Old 04-20-2007, 08:19 PM
CRASH's Avatar
Trader Rating: 26 (100%+)
The 9402 is TOUGH AS NAILS! Use to run these all the time. Still have a couple for backup that still work like new.
Later,
CRASH is offline
Old 04-20-2007, 08:41 PM
SlamMan's Avatar
have you looked at the 9550?
SlamMan is offline
Old 04-20-2007, 10:56 PM
Later,
if i get one of these do i need to run a servo saver..?
Old 04-21-2007, 12:05 AM
Trader Rating: 44 (100%+)
always advisable to use a servo saver, regardless of the servo you use.
wyl03 is offline
