Old 04-18-2007, 11:09 PM   #16
toe out makes the car more unstable but does increase turn in. I avoid it if possible.
ixlr8nz is offline   Reply With Quote
Old 04-19-2007, 12:54 AM   #17
jo90's Avatar
Toe out makes the car tramline on bumps, kinda twitchy in straight lines, but it does allow a more agressive entry into a corner. To be honest it may be better using akerman change to achieve corner entry steering and keep wheels almost parallel
Sponsored by SerpentUK, ModelTech & MTroniks
S400 / MTroniks IP6 / Team Brood / KO Propo = Loads of fun
jo90 is offline   Reply With Quote
Old 04-19-2007, 05:30 AM   #18
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Originally Posted by CAlbrecht
What?....Tow out in the front is your freind ALWAYS...Tow out allows you to come on the straight and let go of the wheel and your car will go down the straght on its own..Trun is better and at exit is smoother and more consistant..
Ackerman ..if you know what it does can help or hurt you..
Listen to this man he speaks the truth
wallstreet is offline   Reply With Quote
Old 04-19-2007, 06:58 AM   #19
Trader Rating: 28 (100%+)
when you are in a turn, the outside wheels are running in a larger radius circle than your inside wheels, by toeing it out(a small amount)your inside tire will effectivly be turned more than the outside tire, making both follow the actual radius they going thru better, ackerman does the same thing but its harder to work with as most cars dont have any way to change it, how much caster you run also affects how much cross weight change you get when turning, so ackerman or toe out will also make a difference there, so always consider that the changes you make to any corner of the car will probably be changing things at the other end too, so if your car turns in better or washes out in the middle or on exit with toe out, a caster change might help. Caster also controls the amount of camber while the wheels are turned.
Mdoc is offline   Reply With Quote
Old 04-19-2007, 07:19 AM   #20
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Run toe-in and wear a ridge down the inside edge of your tires. How can that be a good thing. Some toe-out makes the car a bit twitchy but gives you good initial turn-in when you get to the corners. Try 0 degrees of toe then add toe-out as your driving progresses. Ackerman is something that changes with adjusting toe on a car. Many racers wouldn't know how to adjust it. You probably shouldn't worry too much about ackerman at this point of racing. Wait a few months til you understand toe on a car before opening the next can of worms.
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
Thanks to the SoCal guys that help me & "Tha Man" Paul Lemieux
Racing TC Class where allowed with what I have.
F. Mendoza is offline   Reply With Quote
Old 04-23-2007, 09:28 AM   #21
adamge's Avatar
Alright, I tried it. I went back to toe-out, and suddenly the back straight was super easy. Return the wheel to center out of the straight entrance corner, and whammo: car locks onto a straight line down the straight. I like-ee.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
adamge is offline   Reply With Quote
Old 04-23-2007, 09:47 AM   #22
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Originally Posted by civiceg
does anyone race without toe in the front?
For me, 0 front toe works best on round shaped long corners. It decreases your initial steer torwards rounded corners thus keeps your car's transition smoothly. Toe out works fine if you want more inital steering before corners. Although it also decreases speed on the straights, cause of scrubbing.
Geetoo is offline   Reply With Quote
Old 04-23-2007, 10:01 AM   #23
Toe out works fine if you want more inital steering before corners. Although it also decreases speed on the straights, cause of scrubbing.[/QUOTE]
The loss of speed on the straights in something you cant "feel" . toe-out allows your car to come onto the straight and hold that line until you trun in for the next..
"You dont win on the straight"
CAlbrecht is offline   Reply With Quote
****Revo****Integy Alloy Front, rear and middle-front skid plate set in silver. jf45 R/C Items: For Sale/Trade 6 05-07-2008 11:04 AM
MBX5 Front Shock Tower or MBX5R Front Shocks skelly1344 R/C Items: Wanted to Buy 2 08-09-2007 05:54 PM
3 sets of Front 4wd custum front tires with pics Tony Rivas R/C Items: For Sale/Trade 5 02-20-2007 11:55 AM
Hyper 7 cnc front knuckles/front upper arms trashedmaxx R/C Items: For Sale/Trade 2 09-17-2005 12:28 PM
Alum Tamiya TA04 Front Steering Block / Front Upright Alvin Singapore R/C Racers 2 02-04-2002 06:50 PM
SEO by vBSEO 3.5.0
