Old 09-21-2007, 05:38 PM   #16
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by sim600 View Post
I have the 415MSX and it's not possible to fit a flat LiPo pack (of decent capacity) under the rear bulkhead. I can barely fit the Orion Carbon 3200mah if I grind away the arches above the battery to flatten them but I'm not sure how much this weakens the bulkhead as my grinding gets close to the bearing holder (so this bit of alloy between where the bearing holder ends and the battery begins gets pretty thin). So far, no problems but it does look a bit scary. Thicker packs like today's 4800mah and 5000mah packs are out of the question unless you don't mind having the battery on the outside of the bulkhead (moving weight away from the centre, sacrificing one of the advantages of the stock layout).
Before the photos were released, many people were expecting weight to be moved forward. The 416 has the motor, spur, and centre shaft, shaft bearings and bearing holders moved a bit to the rear. Tamiya claims this is done for traction. I don't know about that but I do know it clears up some room for the battery. Also, this clears up a bit of space on the electronics side so you can fit a chunky ESC in easier.
Also bear in mind that this car will be here almost the same time as the TRF415 MSXX MRE. Which one will TRF drivers be running in big non-LiPo races? Which one will dominate if battery rules change? We shall see.
MaxAmps 5000 packs fit under the bulkhead with no mods.
YOKOMO BD7 2015 :: SMOKEM BD7 2015-IIX Chassis :: HIRO SEIKO Screws :: WTF Windy Fan
veecee is offline   Reply With Quote
Old 09-23-2007, 10:11 AM   #17
sim600's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to sim600
sweet. I never knew. I'll have to see about getting some.
sim600 is offline   Reply With Quote
Old 09-23-2007, 12:37 PM   #18
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Arrow TRF416 Thread
You can check early discussions of the new TRF car on this thread:
Tamiya TRF416 / TRF416WE / TRF416X
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 09-23-2007, 03:30 PM   #19
RC MARKET's Avatar
DEC release
RC MARKET is offline   Reply With Quote
TAMIYA TRF416 W/ SPARES jsfrcfrk R/C Items: For Sale/Trade 15 08-16-2008 06:47 AM
mi3 and tamiya trf416 parts mickrcarver R/C Items: Wanted to Buy 0 04-13-2008 07:54 PM
Tamiya TRF416...in China autostyle Electric On-Road 13 01-26-2008 02:37 PM
Futaba 4PK and Tamiya TRF416 Funkymojo Singapore R/C Racers 14 10-16-2007 04:05 PM
SEO by vBSEO 3.5.0
