Old 04-16-2007, 08:34 AM   #1
Trader Rating: 15 (100%+)
Default Gearing 13.5 on a JRXS
I'm sure this has been discussed but my searches don't turn anything up. I've got a 13.5 with a sintered rotor and I'm looking for gearing recommendations on a JRXS. Relatively short track. Thanks!
Arboleda is offline   Reply With Quote
Old 04-16-2007, 08:43 AM   #2
masterhit's Avatar
Trader Rating: 14 (100%+)
On our shortish (about 72' straight) and tight layout we have been gearing around 1.38, or 35mm rollout. This is foams on carpet however. The motors are coming off at about 135-150 deg. F.
Mike Slaughter
masterhit is offline   Reply With Quote
Old 04-16-2007, 03:54 PM   #3
KHoff7's Avatar
you might want the smaller spur gear for the jrxs to gear it for a brushless because I believe that you have to gear the brushless pretty high and the losi with a stock spur will only do about a 33t pinion before the motor hits the servo
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 04-16-2007, 06:14 PM   #4
losi nut's Avatar
I have my jrx-s geared at 40/128. I'm running rubber tires on an outdoor asphalt short tight track. My 13.5 comes off the track at 105-110 F and the esc(1711 Novak GTB is under 100F. My car has made believers out of a number of brush motor guys, just as much top end speed and killer amounts of torque out of the corners.
losi nut is offline   Reply With Quote
Old 04-16-2007, 07:35 PM   #5
markf3x's Avatar
For Rubber tire carpet with a sintered 13.5
I'm at 112 spur, 40T pinion (and it could handle more)
I use the spur adapter at:
and I use their 112 T Spur.
It works flawlessly on my type R
markf3x is offline   Reply With Quote
gearing for 17.5 and 13.5 2056dennis Electric On-Road 3 06-19-2008 04:00 PM
Onroad clearance Losi JRXS Type R, Jrxs and CRC T-fource pablo101 R/C Items: For Sale/Trade 32 07-30-2007 05:24 AM
JRXS & JRXS Parts Lot vegaskevin R/C Items: For Sale/Trade 5 02-02-2007 09:01 AM
gearing LancerEVO Electric On-Road 9 07-13-2004 05:50 PM
Need help with B4 gearing noline Electric Off-Road 3 06-18-2004 07:31 PM
SEO by vBSEO 3.5.0
