Old 04-08-2007, 06:52 AM   #1
Unhappy X-Ray T2 007
Hello Guys,
I have a question on the T2 007 setup. I am on an Ashphalt track which
has high grip and some fast sweeping corners and some tight corners. What
i would like to know if you help me on is the Chassis Flex Setting. Which of
the three setting would you recommend stiff, medium or soft setting? I was
thinking maybe a medium setting but not sure. Could you help me out here.
Thanks.
skink is offline   Reply With Quote
Old 04-08-2007, 07:31 AM   #2
turboxrayt1fk05's Avatar
Trader Rating: 27 (100%+)
i dont race asphalt but the concept is the same as carpet , the more the grip the stiffer the chassis you want ,i'll subject to start with medium setting and take it from there , if you see to much chassi flex like robbing or anything else
stiff up the shocks for more info on setups you ck teamxray.com , good luck and happy easter
SERPENT S811 AND S811T, FUTABA 4PKS , viper rc solutions
OS SPEED WORLDS EDITION 21 , OS 2060 PIPE
BYRON %30 FUEL , PROTEK 2300 LIPO RX PACK
SAVOX SERVOS 1268MG HV , 1267MG HV
turboxrayt1fk05 is offline   Reply With Quote
Old 04-08-2007, 04:54 PM   #3
Default brushless gearing
I just got a Novak GTB and 13.5 for my T2 007. With the 116 tooth spur and 33 pinion there isn't much room to go bigger. What size spur are most people running with the brushless? I run rubber on carpet. Thanks.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
porschejim911 is offline   Reply With Quote
Old 04-08-2007, 05:22 PM   #4
i use a 100spur (prs) and the highest you could go with that its like 38 or 39, i got a 37 now and it is fast
Old 04-08-2007, 05:24 PM   #5
sorry forgot i run foams , but you want to get betwen 36mm and 39mm rollout
Old 04-09-2007, 07:38 AM   #6
teamgp's Avatar
Originally Posted by skink
Hello Guys,
Thanks.
I would recommend starting with the medium setting and take note of your lap times. Then try the stiff setting and compare the lap times. Whatever is *consistently* faster over a full run is what I would use.
BTW,
I suggest using the existing Xray T2'007 thread for anymore questions. That is the thread that all of the XRAY drivers monitor the most and the forum moderators tend to frown upon duplicate threads.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
