Old 05-11-2011, 11:44 AM   #661
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
I don't know if it lighter I am not finish with my car yet.
SNR Graphite is offline   Reply With Quote
Old 05-11-2011, 12:03 PM   #662
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Yodog- This looks like a worthy candidate for a 1/8th onroad electric.
No doubtedly there's a lot of E4 influence on this design.
YR4Dude is offline   Reply With Quote
Old 05-11-2011, 12:23 PM   #663
MAD916's Avatar
Don't think we can make it anywhere close to lighter than the nitro, we will head to the scales tomorrow night. but the rendering of the model shows (2) 5000mh 5S packs, which for sure is huge but we wanted to explore as much battery real estate as possible. The 2 2650 5S packs for sure are pretty light and may get close but run time was making us want to explore capacity.
The (2) 4000mh 5S packs we have to try are 537g each. I don't think the laws of physics will ever be on our side, an internal combustion motor will definitely have the weight advantage over lipo but that's not our goal, the noise was our goal, and no flame outs, and no pit guy's required...
Plus it's a whole bunch of fun playing with the cool tools available for design
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 05-11-2011, 05:44 PM   #664
wwddww34's Avatar
Trader Rating: 9 (91%+)
Thumbs up
This is what I saw today when I walked into Mike's Hobby Shop...
Will there ever be a 1/8th scale Electric onroad car-kt8s.jpg
wwddww34 is offline   Reply With Quote
Old 05-11-2011, 06:04 PM   #665
a useful study. Thank you.
[URL="http://www.promosyonbank.com/asp/product/663/USB-Bellek&view=2"]promosyon usb bellek[/URL]
flowen58 is offline   Reply With Quote
Old 05-11-2011, 06:23 PM   #666
YoDog's Avatar
Trader Rating: 25 (100%+)
Yeah, this is what I am running these days. (There is a bit of E4 in there...) As the batteries get better and smaller, this design should be the most feasible. it still requires a new chassis but the new parts list is a little shorter than my M3 design which is more flexible as far as batteries go.
With the pack that is in there now, I get 8 to 10 minutes of run time running the Castle MMM. I would hope that maybe Tekin will create some special firmware for the RX8 system that will do some boost tricks like the RS Pro does. Maybe then we can make the power system more efficient. Who's got Randy Pikes ear?
From what I've learned, there is a difficult balance between battery weight and run time. Sure more capacity get's you more run time but at the cost of "real performance". You have to lug all that extra weight around which requires more current and you generate a lot more heat, not only to accelerate the car but also to decelerate. The tires, belts and bearings take more abuse due to the heavier load and it costs more money$$. The real trick is going to be to make the drive system more efficient so it won't require so much power to get the same results. This is the direction I really would like to go. I believe that if the car weighs more than the nitro counterpart, it won't truly be a successful design. Maybe we should shoot for 6 minutes instead of 10 and treat this class like any other electric class.
Personally I'm leaning toward a 2wd pan car design which should out perform nearly any car on the track. Sure it's only 2wd but consider the minimal weight and lack of drivetrain drag combined with massive tires. Imagine keeping all of your old 1/8 foamies from your nitro car to live again on the pan car which likely will be turned to a smaller diameter anyway. That's right, no need to buy new tires for the electric toy!
Man, I gotta stop drinking Monster...
YoDog is offline   Reply With Quote
Old 05-11-2011, 06:37 PM   #667
KostaG's Avatar
Trader Rating: 48 (100%+)
Attachment 750951
I don't think this relates to what this thread is about.
Current Cars:
- Schumacher SX3 & Cougar SV
- Mugen MRX5 WC, Serpent 966e (4s)& Motonica P81e (6s)
Collector/Vintage Cars:
-Serpent F180 (2x), Serpent Veteq, Losi Jrx2, Tamiya Avante & Associated RC10
KostaG is offline   Reply With Quote
Old 05-11-2011, 08:44 PM   #668
RevMaxx's Avatar
Send a message via MSN to RevMaxx
for this converted kit, how would it handle if configured 2WD, much like how a 12th scale EP design.
It should be slightly lighter and less drag on drivetrain. but handling-wise???
i dunno what the handling would be considering rear drive for 8th scale is locked.
RevMaxx is offline   Reply With Quote
Old 05-11-2011, 11:53 PM   #669
YoDog's Avatar
It will work as a 2wd if I install a diff.
I've got an old serpent pro diff which is a really sweet design but doesn't fit directly in either of my cars.
Old 05-12-2011, 12:58 AM   #670
East Bay Pete's Avatar
Rick, I brought this idea to Randy last year. As of late September, or sometime late summer, the RX8 programming now includes timing boost which allows for a user determined starting RPM and RPM at which maximum timing advance is achieved. You can also set how much timing advance you want. This is part of the Vegas software. The software is on Tekin's download page.
Losi 8ight 2.0 Tekin 2050 Combo 4S
Ofna Hyper10 SC Mamba Max Pro / Novak 5.5 2S
Kyosho eEvolva M3 Tekin T8 / Tekin RX8 6S--Track Car
Kyosho eEvolva 05 Tekin T8 / Tekin RX8 S6--Track Car#2
Kyosho eEvolva 05 Castle Creations 2650 Combo 6S--Drag Race Car
East Bay Pete is offline   Reply With Quote
Old 05-12-2011, 01:05 AM   #671
With battery, my car comes in at 3100 grams. It's about a full pound heavier than the nitro. However, without a doubt, this extra weight doesn't affect the acceleration of the car which is considerably QUICKER than nitros. I suppose the main difference comes into play with a "push" into corners.
Old 05-12-2011, 02:27 AM   #672
YoDog's Avatar
Thanks Pete, i was not aware that it worked with the RX8 as well. I run Tekin in my 1/10 scale cars so I'm familiar with the vegas version.
Old 05-12-2011, 10:44 AM   #673
YR4Dude's Avatar
I look forward to hearing about your results.
Also, most club events have only 5 min qualifiiers with 15min or 20min mains. If the battery can last 10min perhaps maybe you can consider designing the battery compartment such that it can open up top like the E4JS or drop out of the bottom like the E4FS/RS. A quick connection for the battery that would disconnect upon battery removal and reconnect upon battery installation would need to be fashioned. I think an RX battery would be best such that the radio would not unbind during battery changes.
Although the battery change may take longer than a nitro fill-up, the added speed of the electric could make-up for the time lost. It would be nice to see how an electric will run against a nitro in a 20min main event or even in a 30min main event.
Old 05-12-2011, 11:04 AM   #674
YoDog's Avatar
One thing to consider is whether or not it's really necessary to run a 20 or 30 minute main. Sure it would be a contender for the nitro class but why run with the nitro cars? If enough electrics come out to make a class of their own, why not shoot for 6 minutes instead, just like any other electric class.
If I manage to get the pan car built, I expect to get over 10 minutes of run time with a 3 cell pack. We could use 550 sized motors since they are becoming more popular and will run on a regular speedo.
If I build the pan car will it sell?
Old 05-12-2011, 12:27 PM   #675
YR4Dude's Avatar
....If I manage to get the pan car built, I expect to get over 10 minutes of run time with a 3 cell pack. We could use 550 sized motors since they are becoming more popular and will run on a regular speedo.
Are you talking about a straight axle car with floating rear pod? Something like an oversized 1/10th World GT car?
WTT Nitro onroad 4 electric onroad rswartz R/C Items: Wanted to Buy 0 02-16-2008 06:22 AM
WTT: 1/10th scale electric offroad for onroad... M2_Driver R/C Items: For Sale/Trade 7 10-22-2007 07:48 AM
Electric heli and 1/5 scale onroad F/S... Nitrobuzzard R/C Items: For Sale/Trade 3 08-18-2007 08:41 PM
1/8 electric onroad?? Saber186 Electric On-Road 2 04-22-2006 11:25 AM
I need electric Onroad xxxssportracer R/C Items: Wanted to Buy 5 05-20-2003 05:00 PM
SEO by vBSEO 3.5.0
