Old 04-07-2007, 06:39 AM   #16
Tpg racer's Avatar
Yea I actually jz bought the new MuchMore pink inserts......havent tried it yet though.......wonder which would be better the pink inserts(soft) or the orange inserts(medium soft).....
Tpg racer is offline   Reply With Quote
Old 04-07-2007, 06:42 AM   #17
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
i guess it would depend on the track... back here everybody is groping for traction since we run on the same track where nitro/foam cars run. all the foam tire dust on the asphalt as well as the oil from the exhaust makes our kits slip like crazy. hahahahaha!
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 04-07-2007, 08:10 AM   #18
PitCrew's Avatar
When building my own tires, I found the Sorex Type C insert to be very good.
Better than the Yok 039F. The tires were better on the first run, and lasted longer. (Previous experience was the Yok 039F was not good on the first run, but a few faster runs, followed by rapid decrease in performance.)
PitCrew is offline   Reply With Quote
Old 04-07-2007, 03:29 PM   #19
2-Bad's Avatar
Trader Rating: 24 (100%+)
If your chasing addition grip have a peek at some Team Bomber, or Xenon, or Hara inserts. The Yok's are brilliant, but only for certain tracks (very flat tracks). The Sorex inserts IMO are only OK... not as good and the ones mention above.
Take Off and Sorex Tyres, well if you remove the insert out of the debate, it will just that depends on the track which is best.... There both good in there right condition.
Hope this helps....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 04-08-2007, 02:30 AM   #20
Tpg racer's Avatar
Have you tried MuchMore and Hpi inserts ???
re using inserts? aus jd 2703 Electric On-Road 4 07-25-2007 09:36 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 08:37 PM
what inserts?? odawg315 Electric On-Road 1 10-25-2005 01:43 PM
Inserts Hugo Electric On-Road 0 06-02-2003 01:31 PM
SEO by vBSEO 3.5.0
