conversion?
conversion?
anyone know how to convert a 190mm into a 200mm?
i mean like putting wheel adapters and longer universals or something to make the wheels stick out more.
do they make longer wheel hubs that make wheels stick out more so 190mm would look right with a 200mm body?
Im not positive but im pretty sure that AE TC3 Rally kit changes it from 190mm to 200mm. You could probably look at that and see which parts they use to make it wider. Just a thought
On HPI cars, they use 2 mm spacers, 3 mm off-set wheels and a smaller lock nut. That's it.
Re: conversion?
i am sure there is a 200mm conversion for the tc3 and it is not a rally conversion .
man I sure would like to know what car??
LOLOL, I hears ya-looking for that stability are ya! Go ahead and throw some 30mm foams on em front and rear! Really, custom widen the car and then throw some 30mm foams on it(front and rear).
Buy wheels with +5 mm offset, if available this much (for sure you can have 3 mm offset). This is easy conversion to any car.
With a pivot ball suspension I;m sure the track is endless as you can lengthen your hubs F/R. Why do you want to lengthen your track?
