Old 03-12-2007, 08:28 AM   #1
Default Gearing Question
Hello everyone, got a quick question about gearing... I am using an Epic Stock 27t motor and I was wondering abiout something...If I increase RPM how should I adjust my gearing. Should I go with a larger or smaller pinion. I am running a TC4 on oval. Thanks in advance Jeff
jeffbhhs is offline   Reply With Quote
Old 05-28-2008, 01:54 PM   #2
what i have been told is to get more speed go with a higher teeth count but going higer will increase motor temp.
pacteam07 is offline   Reply With Quote
Old 06-12-2008, 01:22 PM   #3
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
If you have tweaked the motor for more RPMs but had adequate top end before doing then you should go lower on your pinion. You will achieve the same speed just with more RPMs. If you needed the RPMs to get more speed, then I wouldn't change gearing at all.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 06-12-2008, 04:26 PM   #4
edseb's Avatar
No-not really-well it isn't that simple, increasing the rpm at the motor (increasing rpm is usually done by different brushes, the way they are cut or springs) means you compromised by losing torque (there is always a tradeoff), so it will not be able to pull out of the corners the same, but with the same gearing you will be at a higher rpm and faster on the top end. So you can drop a tooth and regain out of corner speed and still end up near the same top speed since the motor will generate more rpm to compensate. Or leave the same gearing, lose the out of corner aceleration and gain top speed. This works to a point- you still have to worry about load and how hot and inefficient the motor is getting, but in general you will have a starting point.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
XXX-S Gearing Question TeamPink91 Electric On-Road 7 05-15-2010 08:55 PM
AE 12L gearing question. MrZero Georgia Racing 4 11-06-2007 09:42 AM
Gearing question Sal Amato Electric On-Road 1 09-09-2006 12:01 PM
T3 Gearing Question DraKhen99 Electric Off-Road 2 07-18-2003 07:36 AM
Another gearing question Elk666 Electric On-Road 6 05-02-2003 08:50 AM
SEO by vBSEO 3.5.0
