Old 03-11-2007, 01:58 PM   #1
sbs's Avatar
How to clean a one-way diff.?
My one-way diff is not any good ,and I may have to clean it , have any of you a good way how to do it
Soren B. Sorensen
Empty Pocket RC-Team
Serpent S411 / Powered by EPRCT Motor Management
sbs is offline   Reply With Quote
Old 03-11-2007, 04:16 PM   #2
Take it apart and use a greaseless lubricant (eg.LPS1) and spray every part. then use a clean rag and wipe them off properly.now when re-assembling, use a small amount of dif lube for the moving parts too much will gather dirt or dust(same thing) and will cause alot of friction and parts gettin worn quickly
snail run is offline   Reply With Quote
Old 03-11-2007, 05:25 PM   #3
Joel Lagace's Avatar
I flush it with motor spray, whipe out with rag and flush again, light tapping to make sure all the sh#@ is out. Then i use a light bearing oil on each outdrive as i slide it into the oneway
"Without Rules its just Backyard Bashing!"
Joel Lagace is offline   Reply With Quote
Old 03-11-2007, 09:04 PM   #4
Send a message via ICQ to rcnewb2004
for me, i stick motor spray and alchohol into a ultrasound cleaner (never use water with a one-way, i tried it, it will rust). takes all the grit out of it... and use some serpent one way oil on it.
Ta04-TRF, EVO 5
KO Propo
rcnewb2004 is offline   Reply With Quote
Old 03-11-2007, 09:06 PM   #5
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I'm actually getting ready to clean one out will bushing oil or bearing oil work?
UN4RACING is offline   Reply With Quote
Old 03-12-2007, 03:06 AM   #6
Patriiick's Avatar
That s fine also..
Actually, the best lubricant for a one way is transmission fluid...that stuff is MADE for one way bearings..
Patriiick is offline   Reply With Quote
Old 03-12-2007, 03:56 AM   #7
FREAKAH's Avatar
Bushing/bearing oil is too slippery. Use a silicone diff grease like AE's or a specific oneway lube.
Second-Hand Racing
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 03-12-2007, 07:24 AM   #8
Send a message via AIM to R/C Anonymous
X-Ray sells bottles of "One-way lube"
Geoff C.
R/C Anonymous is offline   Reply With Quote
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 07:49 PM
How you guys clean diff az00lude Nitro Off-Road 57 08-02-2008 11:06 PM
NTC3 Complete ATD Diff, diff nut, pivot ball socket caps Judge Joe Brown R/C Items: For Sale/Trade 2 05-09-2008 09:18 PM
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 10:11 PM
XRAY T1FK04, XRC 4.0mm Chassis, One-Way, Diff, Hudy Spring Steel Diff, and MORE! BobbyDoyle R/C Items: For Sale/Trade 10 08-18-2005 03:38 PM
SEO by vBSEO 3.5.0
