Old 03-10-2007, 06:08 AM   #1
gonzo416's Avatar
Trader Rating: 39 (98%+)
can this be used as a power supply? it is a power converter.
Model 9855 55 amps DC output
Input: 105-130 VAC/60 Hz/12.0 AMP (950 W)
Output: Nominal 13.6 VDC (includes charging and load)
Boost 14.4 VDC; Sleep 13.2 VDC
Dimensions: 7" W, 4 H, 10.2 D
gonzo416 is offline   Reply With Quote
Old 03-10-2007, 06:31 AM   #2
You can use that as a power supply to run a charger or other 12v rc duties. It is made for RV's to power the 12v system when they are hooked to regular power. They usually have real clean power outputs.
JimMcClure is offline   Reply With Quote
SEO by vBSEO 3.5.0
