Old 03-08-2007, 08:14 AM   #1
acutts's Avatar
Default Problems with Much More CTX-D Discharger
I seem to be having problems with my CTX-D. Whenever I discharge a pack the 6th cell is always extremelly low compared to the other cells in all my packs and this cell discharges first.
Is this a problem with the discharger? Can it be repaired?
I see there is a version2 available is this better and can mine be upgraded?
acutts is offline   Reply With Quote
Old 03-08-2007, 08:20 AM   #2
Trader Rating: 38 (100%+)
On all packs or just a particular pack? Make sure the screws arent backing out during the discharge. A screw coming un-done during the discharge isnt seen as an error condition just that the voltage dropped down to 0 and it stops discharging. (by the way if that cell isnt getting discharged then dont charge the pack as the cell will probably explode - I saw it happen a month ago, very scary)
or8ital is offline   Reply With Quote
Old 03-08-2007, 08:34 AM   #3
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
If the CTXD is still discharging cell #6, the unit may need to be recalibrated. Have you tried to discharge your packs on another CTXD or CTXD2? As or8ital said, you definitely don't want to charge the pack and risk the cell exploding.
Have you flipped your fans around? If not, give that a try and see if you still get the low reading on cell #6.
If the CTXD does need repaired, you will need to contact Muchmore UK for service. MM did have upgrade kits available at the time of the CTXD2 release, but you would need to check with MM UK to see if they still have any available. The upgrade does not include the extra posts, it's a internal upgrade.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
what's the diff btwn 0-30 discharger & novak smart discharger straightaway Electric On-Road 9 09-12-2006 06:15 PM
ctxd discharger problems Xrayskid Electric On-Road 2 08-11-2006 08:06 AM
is this discharger a good one? Venom Battery Discharger aquito Electric On-Road 6 05-09-2006 01:21 PM
Duratrax 20 Amp Discharger, Indi Zerothirty-030 Discharger NOTFASTENOUGH R/C Items: For Sale/Trade 8 05-05-2006 07:07 PM
Wanted Integy Octane 2 Discharger or Trinity Realtime 2 Discharger FUK_WRX R/C Items: Wanted to Buy 0 08-02-2003 04:23 AM
SEO by vBSEO 3.5.0
