Old 03-03-2007, 06:10 PM   #1
Default Steel pinion for TT-01
Im after steel pinions for my TT-01, cause im just going through alloy's. I have been told to use the robinson racing 48 pitch metric steel alloy pinions (.6 module). Is this correct though?
REC'd Racing
What I have - Brushless Slash 4600kv, DX2S
What I need - Boss Motorsports 10.5, TRC LCG chassis, Ford F-150 SC body, Proline Protrac & a Brushless XXX-T CR MMP4600kv. Not alot!
Drift Demon is offline   Reply With Quote
Old 03-04-2007, 03:39 AM   #2
peter p's Avatar
Tamiya use there own pitch,not 48 metric what you need is the pinon that tamiya call AV.I dont think anyone else makes them.
peter p is offline   Reply With Quote
Old 03-04-2007, 06:20 AM   #3
If you look HERE Towerhobbies says the AV pitch pinions are 48p metric. So that means you should be able to use THESE .
dway100 is offline   Reply With Quote
Old 03-04-2007, 10:00 AM   #4
sosidge's Avatar
It is a bit misleading to call the metric 48dp, the tooth profiles are totally different, but you can use those robinson pinions.
Old 03-04-2007, 02:14 PM   #5
forum fodder's Avatar
It is a common point of confusion and i have seen many a stripped spur gear because of it. Tamiya pinions (and other makes as there are some) that have 0.6 module or indeed the fine pitch 0.4 module are not the same as 48/64dp gears. They are close and will run together for a short period of time, but not long til is knackered.
dp (with stands for diametrical pitch) is an imperial measurement and is the number of teeth of that size you can get round a 1inch diamtre gear. Module is the length in mm for each tooth on the pitch circle diametre.
for example 48tooth 48dp gear is 1 inch diametre. 48 tooth 0.6module is 48*0.6 = 28.8mm or 1.134inches
Basically 1 is metric (gear module) the other is imperial, so its like fitting a inperial screw into a metric thread, with a bit of force you might get it in, but you are screwed if you want to get it out. (sorry for the pun)
Unfortunately not everyone will learn this and gears will continue to get stripped, just dont believe everything the bloke in the shop says!!!
forum fodder is offline   Reply With Quote
Lot of 14 Pinion Gears, 2 Pinion Holders, and 3 Spur Gears (64 Pitch) MyRCTrader R/C Items: For Sale/Trade 4 02-04-2008 06:08 AM
Would switching from a 19t pinion gear to a 21t pinion make a big difference ? thahookup Rookie Zone 5 05-19-2006 12:09 PM
The Man of Steel dpalXRC Painting, Designs, Graphics and Photography 41 11-30-2005 01:26 PM
Kyosho V-One RRR Hard Steel Pinion released rcKenon.com Nitro On-Road 3 11-26-2005 11:03 PM
SEO by vBSEO 3.5.0
