Old 03-03-2007, 02:45 PM   #16
that is James35 car. he is here.
Originally Posted by RC Guru
just wondering...anyone know how to achieve this?
MManson is offline   Reply With Quote
Old 03-03-2007, 03:11 PM   #17
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
A lot of people are using these. (Well, maybe just plane guys) I've been using them for other applications, and they work OK.
Ed Anderson is offline   Reply With Quote
Old 03-03-2007, 11:12 PM   #18
I've look into astro flight plugs but then problem is when you goto brushless to brush motor you need the two negative to be together... which is a probably with those plug unles you mod it somehow.
those could be used for brushless / brushless swap.
drifterrolly is offline   Reply With Quote
Old 03-04-2007, 05:18 AM   #19
rcgen's Avatar
I use the 3.5 mm bullet connectors for my brushless and brushed setups.
Brushless mode
Brushed mode
Wiring connector for brushed
rcgen is offline   Reply With Quote
Old 03-04-2007, 06:05 AM   #20
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
i think i know who your talking about...i remember he runs / ran a rc18t...and has a body scheme with liek green white and black. i remember seeing him at socal and talked to him a few times...is his screenname on here HB moose?
Yes, he's the guy. Very friendly and easy going. HB Moose is his sceen name on these boards. He helped me with mine. His set-up and mine can swap each others BL motor for racing, practice, or to try different speeds. I have a conversion harness for my brushed motors. I can pull the brushed motor and harness for BL. No soldering to use my brushed motor with my GTX car or my GTB car. No soldering to go to and from BL in my GTB car.
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
Thanks to the SoCal guys that help me & "Tha Man" Paul Lemieux
Racing TC Class where allowed with what I have.
F. Mendoza is offline   Reply With Quote
Old 03-04-2007, 08:44 PM   #21
rcdy's Avatar
I think its 2 deansplug glued together to have 3 soldering tabs.. that should make it easier to switch motors, and even switch from brush to brushless.
TeamXray, TeamAssociated, Esky, Tamiya
rcdy is offline   Reply With Quote
New guy want to switch to brush less ?s jerm Electric Off-Road 8 03-03-2008 06:05 PM
3 pin Deans for easy switching from brushless to brushed. Katana Man Electric On-Road 22 07-14-2007 05:57 PM
Easy Switch Between Brush and Brushless mackin Electric On-Road 1 07-14-2007 05:42 PM
How to make fans on a switch... XrayFK05 Electric On-Road 17 09-01-2005 03:38 AM
Why some of RC model are easily unwanted??? Eric Cheng Singapore R/C Racers 30 07-29-2003 01:31 AM
SEO by vBSEO 3.5.0
