Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-21-2007, 05:51 PM   #31
EAMotorsports's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by beyondthepack
...and when or is it availible?
It is available now....You can email me to see.
EA
RCAmerica | Xray | Hudy | EAMotorsports | SMC | Jaco | PRS | Killer Concepts | TNT-FX.COM | Futaba | P1 Brand | JConcepts | Parma.
EAMotorsports is offline   Reply With Quote
Old 02-21-2007, 07:30 PM   #32
voodoochild's Avatar
Send a message via AIM to voodoochild
Originally Posted by EAMotorsports
Im going to go ahead and start a thread for Josh and hope he doesnt kill me . Use this for all CEFX related questions and I'll try to answer them and I am sure Josh will pop in here when he has time as well. I'll post my setup from the Birds here in a few along with pics.
EA
Looks like this is the EA 1/12th scale thread to me
Jamie Tennies
I.I.C. 2009
Trackside.com
K.M.A.R.
voodoochild is offline   Reply With Quote
Old 02-21-2007, 08:08 PM   #33
wyd
wyd's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to wyd
Well he seems to do well with the car so its great to have him posting.
Team Driver for:
Castle Creations
Bumps and Jumps
Express Motorsports
D&K Air Designs
Karens Famous Cookies (Factory Team Eater)
The Hidden Hangar
Old 02-21-2007, 08:09 PM   #34
Switch Blade's Avatar
Send a message via AIM to Switch Blade
I am seriously thinking of buying one to run at the nats, and coming from an L4 I dont think the leap will be too bad. The only questions I have are: is the stock chassis suitable for high traction, or will most go to the wide chassis? And lastly, what are the handeling affects of the short, medium, and log t-bars?
one more, what do most use to dampen the rear end? Grease such as the trinity white, red, and purlpe stuff, or silicon diff fluid?
thanks, chopsticks
College
Switch Blade is offline   Reply With Quote
Old 02-21-2007, 08:14 PM   #35
WOW I feel special....One of Jamies 24 post were used for me!!
EA
Old 02-21-2007, 08:16 PM   #36
Super Moderator
Kraig's Avatar
Trader Rating: 29 (100%+)
Yeah, we finally taught him to how to turn the pc on.
I started with nothing and I have most of it left.
Kraig is offline   Reply With Quote
Old 02-21-2007, 08:17 PM   #37
thanks, chopsticks
It should be an easy transition. I am pretty sure my car is just a stock car out of the box. Josh didnt say anything was special about it. I have the medium Tplate on mine. Josh said that it works in most applications. The shorter bars were meant for Asphalt I think. Longer ones are the same as associated. The reason for the medium length bar that is standard is the rear pod is bigger than most and it helps to keep the lenght from the rear axle to the pivot point the same as other 12th scales I believe.
Most guys are using some sort of gas car diff silicone for the tubes. I know Josh uses Kyosho stuff. A lot of guys use Associated stuff as it comes in an assortment pack. 15,000wt Kyosho is what Josh starts with everywhere.
EA
Old 02-22-2007, 07:22 AM   #38
Are you running the t-bar flat or do you have a shim under the front pivot ball?
Apex is offline   Reply With Quote
Old 02-22-2007, 09:31 AM   #39
As promised in the 1/12th thread, here is the CEFX C12 set up sheet I've been using. It's an Excel spreadsheet, so can be extended and expanded fairly easily
It's designed for the new chassis, but wouldn' take much to convert back to "old skool" Evo 1 kit format!
I've been running Associated thin t-bars, and haven't gone back to the CEFX t-bars since. Not sure how the new cars have come, but I've been using a post to mount the front of the shock above the front t-bar screw. A faithful copy of Josh's 2006 Worlds set up...I did pit right next to him so got a ring side seat
Side dampers - I've run Corally Soft damper lube, and increasing using Losi Hydra fluid...either medium or heavy.
Cheers, MarkB
MarkBurgess is offline   Reply With Quote
Old 02-23-2007, 11:02 AM   #40
wyd
wyd's Avatar
Well just paid for my CEFX car so I think by the end of next week I will have it. Going to be interesting because I raced lots of different cars and classes before but never a 1/12th. This is going to be a whole new ball game for me. Look forward to the challenge of concentrating for 8 minutes.
Team Driver for:
Castle Creations
Bumps and Jumps
Express Motorsports
D&K Air Designs
The Hidden Hangar
Old 02-23-2007, 11:18 AM   #41
.040 under the front ball.
EA
Old 02-23-2007, 12:13 PM   #42
1fastdude's Avatar
What's the schedule for the Regional's next week?
Team Horizon-Team Spektrum-JR Racing-John's BSR Racing Tires-Parma/PSE-Team Epic-Team Shepherd-Team Corally-CEFX-TQ Racing Products-RCAmerica-Max Power Engines-Rocket Science Fuel-Finish Line-TNT-FX.COM-PRS Gears-Dynamite-YBSlow-Muddslide Motorsports-Tri-State Hobbies and Raceway
1fastdude is offline   Reply With Quote
Old 02-23-2007, 12:21 PM   #43
3 Quals Saturday. 1 Qual and Mains on Sunday. Call CEFX for more info.
EA
Old 02-23-2007, 12:41 PM   #44
EA
Ok, now I understand your setup and why you're generating more rear grip.
Thanks!
I just got a kit a few weeks ago and will be trying it out next weekend. I'm gonna start with a long t-bar and see what happens.
Old 02-24-2007, 12:01 PM   #45
Josh Cyrul's Avatar
Hey everyone,
Sorry for my delays in getting up here.... After finishing up at Ft. Myers, we had a death in the family and in trying to get ready for the Nats I've run myself into the ground with a serious sinus infection/cold.... I'm way behind with a lot but I figured I'd post since EA was doing such an awesome job helping us out with things!!
Some basic info:
3 chassis types:
Standard - Same as AE
Medium - .050 wider (1.25mm aprox.) - This is what comes in the Evo2 kit
Wide - .100 wider than standard (2.5mm aprox.)
4 t-bar types:
Long t-bar - Large tracks with low grip where tons of rear bite is needed
Medium - good all around t-bar - Very similar to AE t-bar in handling
Short - mainly for asphalt racing - short to increase stiffness quickly for increased steering and traction (too aggressive for carpet)
Standard - Copy of AE t-bar - this will fit on the C12 but it is not recomended now that we have the new t-bars.
EA's car was a box stock C12. Nothing special or prototype about it.
CEFX, T.O.P. Racing, Thunder Power, Shepherd Micro Racing, Novarossi, Jaco, Hacker, Ko Propo, Kimbrough, Faskolor, MuchMore & Reilly Paint
www.cefx.net - www.topracingusa.com - www.thunderpowerrc.com - www.team-shepherd.com - www.kopropo.com/america - www.novarossi.com
Josh Cyrul is offline   Reply With Quote
Forum Jump
The Racing Thread chicagokenji Micro and Mini Scales 8 02-20-2007 06:40 AM
CEFX Raceway - Summer Racing Schedule Josh Cyrul Track Locator Forum 0 05-30-2006 04:16 PM
Drag racing thread mrgsr Australian Racing 4 11-05-2005 12:10 AM
GS Racing S.U.T. Thread Fatboy Joe Monster Trucks 5 07-27-2004 06:53 AM
Mad-Rip Racing Thread (where 'd it go?) amusicwiz Florida Racing 1 03-28-2004 06:03 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
