Old 02-18-2007, 07:11 PM   #1
Iceracer's Avatar
Default Did I blow my ESC?
Just a last ditch trouble search before I cut the leads off and throw it in the garbage.
My Novak Duster II ESC suddenly stopped working when I put my car back onto the track. Thought my batteries were dead, but they weren't. I was running a 19 turn motor which it should be good for. Now the motor will barely turn over. Steering servo works fine and so does receiver. Swapped motors, swapped batteries, tried the one touch setup again,same result. Will barely make a motor turn over. The leds light up properly to show neutral, full throttle and brakes. I opened up the case of the ESC and nothing looks or smells burnt, yet it wont work.
Throw it out?
Iceracer is offline   Reply With Quote
Old 02-18-2007, 07:33 PM   #2
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Check your end point adjustments on your radio to see if they have not been messed with on the throttle.
CarlosG. is offline   Reply With Quote
Old 02-18-2007, 08:48 PM   #3
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Don't throw it out open it up and see if you can see whats wrong, call Novak and see what it will cost to repair it. You may open it and see a piece of lint or dirt. If its shot make a brush case or bearing case out of it.
UN4RACING is offline   Reply With Quote
Old 02-18-2007, 10:09 PM   #4
Speedie's Avatar
Hope ya figure it out but if ya dont dont throw it away. Novak will take it back in trade on a rebuilt one.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 02-18-2007, 10:12 PM   #5
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Iceracer - I would definately suggest calling or e-mailing Novak's Customer Support team. They should be able to help you better than most people on here to troubleshoot your speed control, and/or set you up for a repair if nessisary.
Several of them post here on RCTech to, so hopefully they find this.
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Did I blow up my esc? wstuart Electric On-Road 14 06-02-2008 07:32 PM
Blow Out Tony Vega R/C Items: For Sale/Trade 18 08-02-2007 09:19 PM
ST-r Blow-out chowderhead72 R/C Items: For Sale/Trade 14 06-14-2007 07:35 PM
Did I Blow my GTX? cpatel529 Electric Off-Road 5 03-23-2007 03:31 PM
Did I Blow It? rustyrever Monster Trucks 12 05-18-2006 06:31 PM
SEO by vBSEO 3.5.0
