Old 02-08-2007, 03:01 PM   #1
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Default how to ..one way bearing maint.
As the title says...maintenance on a one way bearing. Do you use oil or grease..how do you guys maintain yours. I just got one for my XXXsG+
Dasupacat1 is offline   Reply With Quote
Old 02-08-2007, 04:07 PM   #2
rpoage's Avatar
This is from our old web site but it still works
One-way bearings
"The care and feeding of one ways."
A one way bearing is a amazing device. If you ever have a bad one don't toss it out until you have an opportunity to do autopsy. You will find needle bearings housed in a steel housing with the needles seated in a nylon race. It's really not like a bearing and race though as the nylon part is bonded to the steel housing. The real work horse in the one way is the thin curved strip of steel placed next to each roller. When the driven shaft (tight tolerance) rotates past the needle in one direction no problem but try to go the other way and the unit will jam and the driven shaft and the one way will operate as one. The one way requires several key points to work correctly:
1) tight tolerances
2) good lubrication.
3) A clean environment.
The tolerances are really up to the factory but when wear becomes noticeable on the driven shaft or adaptor the one way's can fail.
Good lubrication is easy. Just enough oil to wet the one way's but not enough to attract dirt. As for what oil to use, I have had good luck with mineral oil and with Mobile One. In 1999 Serpent introduced SER 1680 one-way lubricate to correct a high failure rate on their one-ways. I have to admit that this stuff really works and it is now all that I use. More on chemicals later.
As for the clean environment if dust and dirt are kept off of the outside of the one way and its components this is a good start. If you clean your car off with compressed air try not to blow the dirt into the one ways or bearings but rather away from them.
Chemicals: The easiest way to kill a one way is to damage the tolerances. If an oil or cleaner swells the nylon even a little the first thing you will notice is some parasitical drag on the one way or if enough damage occurs you can have slippage or complete lock-up. I learned this by cleaning out my one way's with electric motor spray a number of years ago and then not being able to refit them to the drive axles until the swelling went down. The one ways never worked quite as well and ultimately requires replacement. For this reason I clean my one way's by flushing them out with more of what ever oil I'm using. I'm not suggesting that this is the only right way to do things only that it works for me.
SER 1680 One Way Lube
Ashford Hobby
Real time inventory for the things you need.
rpoage is offline   Reply With Quote
xxxcr new body /2 gtxs /orion mot maint 2056dennis R/C Items: For Sale/Trade 38 04-11-2008 03:35 PM
wanted. Slapmaster thrust bearing or Axiom thrust bearing... Tron 101 R/C Items: Wanted to Buy 1 03-24-2008 09:34 PM
Brushed Motors and all the maint. tools and supplies GroffBall R/C Items: For Sale/Trade 4 09-18-2007 05:59 AM
Bearing Help please Ill Factor Electric On-Road 1 02-06-2007 07:08 PM
Ceramic Bearing VS Normal Bearing MRX_joe21 Nitro On-Road 25 11-19-2005 10:09 PM
SEO by vBSEO 3.5.0
