battery readings
hello
i was wondering how i would find out if my battery's are charging to full capasity. The batteries that i was concerned about where 3000mah nmh, 2400mah nicd and 1700mah nicd. any sudgestions?? |
what kind of charger are you using?
im using an omni (probily unknowen to you unless you live in australia). the charger has an amp meter that tells you what amp they are charging at and the charger can charge up to 4amp 1-10cells
any one have any ideas
battery readings
With the information that you gave us, I would say if the batteries are warm when they come off the charger, most likely they are fully charged. I prefer chargers with Digital amp, voltage and Mah displays. Then I know for sure what's going on with my Batts.
You have a link or picture of the charger? |
