Pro 3 carpet setups
Hello all
I have an HPI Pro 3 and i'm looking for carpet setups. HPI Pro 3 with Penguin chassis and side plates Penguin front & rear shock towers Hot Bodies upper deck We're running on carpet and the current track setup is , I would consider, small and tight No sweepers and a somewhat short back straight. We run open tires, no foams though. Any setups would be greatly appreciated Thanks to all who view!!!!!!!!!!!! |
Take a look in the Pro 3 thread - I'm sure I posted a carpet setup in there if you do a search, although I run foams.
Right now I run a fullly optioned chassis with the cross lower chassis plate and 2 hb upper decks stacked and expoxied together.
Front: Grey pro linear spring, 65wt oil, #4 piston, silver swaybar, 6 degrees of caster, 1 degree of toe out, 1.5 degree of camber, 3.5 mm rideheight Rear: Grey pro linear spring, 60wt oil, #3 piston, black swaybar, 2 deg of rear toe in, 2 deg of rear camber, 4.0mm ride height Motor: Team Orion Core 9x2 Gearing: 29/118 Tires: Sorex 24R in front, 20R in the rear Inserts: Hpi Red molded inserts Body: Hpi Stratus (lightweight) Servo: Ko Propo 2173 Dual ball diffs on tight track, center oen way for medium track, dual one way setup for large tracks |
