Old 02-02-2007, 10:10 AM   #1
Default Buzzing servo noise
Is it normal for my airtronics 94758Z to make a buzzing noise while at idle?
galois427 is offline   Reply With Quote
Old 02-02-2007, 10:34 AM   #2
rc-zombies's Avatar
if it's a digital servo.. that's normal..
Old 02-02-2007, 04:13 PM   #3
gubbs3's Avatar
Either analog or digital will buzz when it's trying to find it's center. Analog is just a much lower frequency so it's a little harder to hear. Digitals do make a fairly audible squeal.
This is also a good way to set your endpoints. With the wheels off the ground you should be able to turn lock to lock without the servo "buzzing" at either end. If it does you need to turn down your endpoints to make sure you don't burn out your servo.
gubbs3 is offline   Reply With Quote
Old 02-02-2007, 06:38 PM   #4
Iceracer's Avatar
Check for binding in the linkages. If it has to fight the bind at centre it will work continuously.
Iceracer is offline   Reply With Quote
buzzing sound from old servo Molala3 Electric On-Road 1 04-20-2008 10:34 AM
Servo has buzzing, cracking noise. cooliomojo-CEBU Electric On-Road 4 11-19-2004 10:21 PM
servo buzzing??? dstyles Electric On-Road 7 10-07-2004 04:25 PM
Servo Buzzing? Pirvan Nitro On-Road 4 09-15-2002 01:35 PM
SEO by vBSEO 3.5.0
