Old 01-26-2007, 09:24 PM   #1
yeaklet4's Avatar
Trader Rating: 34 (97%+)
Default eagle mod lathe troubles
i just got this thing and when using it the arm like jumps up and down and side to side i think the oring is a little loose would that cause it to do that.
yeaklet4 is offline   Reply With Quote
Old 01-26-2007, 10:13 PM   #2
fathead's Avatar
An old o-ring could be the problem
Check to make sure the lathe is spinning the right way, the part of the comm that faces you should be coming up.
If you don't have the adjustable right mount (I have the adjustable) you will need to use a pinion on the arm to stop it moving side to side
Slavich Design
fathead is offline   Reply With Quote
Eagle Lathe and GTX carsrule692 R/C Items: For Sale/Trade 17 02-16-2008 05:25 PM
LRP X11 4.5 / Eagle lathe ScottyP Australia For Sale/Trade 1 11-20-2007 03:02 PM
EAGLE LATHE lem2 Electric On-Road 0 07-27-2005 04:21 AM
Mod. eagle com lathe KREATOR1 R/C Items: For Sale/Trade 0 05-25-2005 10:23 PM
Eagle lathe Just got one Electric On-Road 7 04-30-2004 07:50 PM
SEO by vBSEO 3.5.0
