KO PROPO EX-7
KO PROPO EX-7
anyone remember this radio...i need a compatable receiver for it..all the info i have is the crsytal is a 27 Mhz one...
any recommendations..?
Check out the K.O. website; www.kopropo.com Although they may not sell the radio anymore, they should have a receiver that will work with your radio.
Good Luck
Loren
Good Luck
Loren
Originally Posted by Grizzbob
Correct, the EX-7 is an AM radio, so you should be able to use most any 27MHz Am receiver, which means ones like the LRP Phaser or Novak XXL should work fine.....
Loren
i also heard about the negative and positive thingy...
anyway..will go down to hobby shops to check out those recommended receivers here...
Super Moderator
Originally Posted by llamont
Will a Futaba AM Rx work with a KO AM Tx? I thought they were different shifts (Futaba, Negative and KO, Positive)?
Loren
Loren
