prs spurs gears
has anybody used the prs spur gears on a tamiya trf415 msx mre?
I pick up some and for some reason the holes does not align.only two holes can align.do i need an adapter?
You probably got the regular spur and not the Touring car version. Mine fit well.
no, i got the touring car. but i notice on the car manual that you only use two screws instead of four. can you guys confirm that?
Yes on the 415 there are only 2 holes on the spur gear mount. Just don't over tighten if you have the graphite plate on it.
shouldn't have alignment problem with PRS spurs except if u change the original spur holder to square spur holder, i found PRS spur won't align well by a notch to the latter
