Old 01-22-2007, 01:52 AM   #1
howard1's Avatar
Default Ideal Battery Charging Tempratures??
One reads much about batteries and charging, but is there an optimum temprature to charge batteries at? In that it all has to do with the interaction of chemical compounds which react do produce voltage in a battery there must surely be an ideal temprature at which these reactions occur best and produce the best results without damaging the battery.
I live with FEAR everyday, and sometimes she lets me go RACING!
howard1 is offline   Reply With Quote
Old 01-22-2007, 06:15 AM   #2
UN4RACING's Avatar
Trader Rating: 22 (100%+)
The cooler the better I would say 120 degrees. I would check with the closest battery mad man at the local track. It depends on the battery.
And the method of chargeing, that you use.
I just charge mine till they vent and then never get'm that hot again.
There was a great article in Extreme R/C magazine on that very subject.
A Special Thanks to Arno and Rigor for there support...
UN4RACING is offline   Reply With Quote
Old 01-22-2007, 01:12 PM   #3
howard1's Avatar
What I am referring to is that "sweetspot" temperature at which a battery accepts charge best. Does it exist? We know that a freshly charged hot battery performs better than one that has stood and cooled. Muchmore make battery warmers, why? If there is such a "sweetspot" then one could build a thermostatically controlled device to maintain that temprature while charging. This should then result in peak performance from the battery with no heat damage! Has anyone done this type of testing and what were the results.
Old 01-22-2007, 06:57 PM   #4
Its very hard to say which is the sweet spot.
Ambient Temperature changes everytime. Set your charger at about 120 F.
I use the temperature as a safety parameter, so that I won't cook my cells. You should set your charger peak detection voltage to about 0.3v per cell if you're using IBs and the temp is just like what I've mention a precautionary parameter.
Ben.C is offline   Reply With Quote
Old 01-22-2007, 08:44 PM   #5
imjonah's Avatar
Default Hmmmmm
My understanding was that the sharp rise in temp is the result of the battery being "full" and so any additional charging is turned into heat. Peak detection allows unattended charging but if you were to monitor temp carefully you could pull the battery off the charger at the ideal time, by watching temp alone.
imjonah is offline   Reply With Quote
Old 01-22-2007, 09:29 PM   #6
I think your asking to much here, The IB cells do seem to perform better when they are warm, but I dont think trying to warm them externaly will work. They have to be warmed internaly, and the only way to do that (as far as I know) is by charging them or repeaking them if they sit to long after the charge. Warming them externally may help a little, but probably not enough so that you could tell. And to my nollage, the cells always take a better charge when they start out cool and then warm up internally. But hey, if you find any thing that works let me know, I'll try anything that works. AL
Remember, Every thing I post is just my opinion, But if you don't agree with it, You know where you can go.... LOL
Al Schwarze
MEGAVOLTS is offline   Reply With Quote
Battery Charging rf096 Racing Forum 16 06-01-2015 02:24 PM
Battery Charging FAQ dr_catman Singapore R/C Racers 55 04-29-2007 08:50 PM
Battery Charging t4mania Electric Off-Road 7 08-16-2006 08:41 PM
Battery charging help fordman86 Electric Off-Road 12 04-19-2006 10:23 PM
RX and TX battery charging help keyzs4 Rookie Zone 4 01-12-2006 01:11 AM
SEO by vBSEO 3.5.0
