Old 01-19-2007, 10:49 PM   #1
Unhappy ESC problem plz help
see the attach pic
i want this circuit(brushless motor) work with out the receiver how?
just like the attach pic
the ESC is:
the brushless motor:
plz i need this to work
al000y is offline   Reply With Quote
Old 01-20-2007, 06:03 AM   #2
PerformanceRC's Avatar
PerformanceRC is offline   Reply With Quote
Old 01-20-2007, 06:27 AM   #3
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
I've never messed around with butchering an ESC before.
The red wire is positive.
The brown wire is negative.
The orange wire is the signal.
You will also need a variable resistor. Like a volume control or trigger type control.
The best thing is to plug it up properly with a receiver. if you are not good with electronics you will burn this system up. What you want is obtainable but I don't know that using that stuff is the way to go for you. Why not just use a motor with a vatriable resistor. That way you don't damage the ESC you have. Good luck with your project.
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
Thanks to the SoCal guys that help me & "Tha Man" Paul Lemieux
Racing TC Class where allowed with what I have.
F. Mendoza is offline   Reply With Quote
Old 01-20-2007, 04:04 PM   #4
Iceracer's Avatar
A receiver outputs a special signal to the servo or esc. It is not simply a varying voltage or resistance. You could build a circuit to drive the esc, but it would require a special integrated circuit to drive it.
Take a look here at the details of the signal that drives a servo or esc:
Iceracer is offline   Reply With Quote
ESC PROBLEM ghj1997 Electric Off-Road 13 06-04-2008 07:38 AM
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 08:07 PM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 06:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 04:08 AM
SEO by vBSEO 3.5.0
