Need some Touring help traction problems
#16
Originally Posted by wcalaker
On carpet I ran copper springs in the rear with 50w and yellow up front with 70 weight. 3 Hole Pistons.
Droop 5 on front and rear. Using AE Droop guage
Caster block - 4 degrees
Camber - 1.5 f/r
Try moving the battery in the "rear" placement. This will give you less steering.
Could be wrong tires. Ask around to see what everyone else is using.
Camber - 1.5 f/r
EDIT: also forgot to mention positioning of shock towers, the front is placed on the 3rd one in(changed this) and the rear is on the first i think(how it came )
#17
Try the Black roll bar. Front only.
Oh yea..Rear toe in about 2-3 degrees. Whats your alignments ?
When you sauce the fronts sauce only the inner half of the tire, not the entire tire.
Good luck
Good luck
