Old 01-17-2007, 01:50 PM   #31
gubbs3's Avatar
I too have a GT7 in my 1/12 and it doesn't offer much for braking. Maybe its the profile (6) but full brakes doesn't do much. But really, how much would you ever need in 1/12 stock? I don't use any, no matter what track. I'm a long time nitro racer so I learned to drive using no drag brake at all so electric has taken some getting used to. The two tracks I race at are very different, one being about 100x40 and the other I think is something like 50x30! For both I use just a very small amount of creep. Just enough so the wheels keep turning when they're off the ground. Then it feels like it is freewheeling like a nitro. I have had some pretty good success at club level for the short time I've been carpet racing but from all my experience, the best drivers actually drive the car. They don't let the radio do it for them.
gubbs3 is offline   Reply With Quote
Old 01-17-2007, 03:44 PM   #32
Registered User
First, what's the theory behind choosing a drag brake setting? I'm sure this varies some with driving styles and preferences. Now that I'm running brushless it doesn't seem to have the same drag brake or cogging the brushed motors do. That's adding some more confusion. Some of the fast guys at the local track seem to suggest running little to no drag brake. How much weight should transfer if any to the front under neutral throttle or should it just coast?
Much of the reason for running drag brakes is consistency. You can setup drag braking in a car for consistent roll through a corner since you just have to apply throttle to keep your speed up, or slightly let off to slow the car down; if it's simply up to you to brake going into the corner unless you've got one heck of a finger you won't always use the same amount of braking in the same corner time after time, where as if you have your drag brake setup correctly for the course all that is required is letting off the throttle.
It all depends on the car, setup, and the track. When racing stock rubber I have no brakes, no drag brake and I rarely lift the throttle. In 19T foam I use just a touch of drag brake (maybe 10% if that) to slow the car and aid in rotation, and add a little weight transfer to the front for steering.
Desolas is offline   Reply With Quote
Old 04-30-2007, 10:11 PM   #33
Can someone explain how to adjust these features. Does the GTB have drag brakes or the transmitter itself. I have a m11 and it has a drag brake feature, but have never used it. I also have a Novak GTB w/ 4.5.
silence360 is offline   Reply With Quote
No brakes. wes95_z28 Nitro Off-Road 10 05-22-2008 06:38 PM
Help Ive got no Brakes!!! TRFTIM Electric On-Road 5 09-06-2006 01:11 PM
which pro driver you know uses drag brakes? cyba888 Nitro On-Road 2 11-24-2004 11:14 AM
driving styles bughead Rookie Zone 31 09-02-2003 11:37 PM
Driving styles zoombie Electric On-Road 23 05-23-2003 07:35 PM
SEO by vBSEO 3.5.0
